Alignment, done ! |
Alignment, done ! |
J P Stein |
Mar 6 2003, 03:19 PM
Hey, we went out in the rain today.
Fortunately the alignment chop is only a half mile away. Here's what we gots: Camber R/F -1.99 L/F -1.99 R/R -2.3 L/R -2.25 Caster R/F 5.08 L/F 5.31 1/16 toe in at both ends. Pulled another 3mm shim from each side in the rear. I"d like to get more caster, but I'd have to do some more grinding around the strut mounts. Maybe next winter. A short drive shows the car to be VERY responsive. The ride is....er....firm....but not as bad as I thought it would be. Vracers really suck in the wet. Now if the weather would cooperate, we can go play Sunday. It ain't lookin' good, tho. |
Sammy |
Mar 7 2003, 09:12 PM
. Group: Members Posts: 1,190 Joined: 21-January 03 From: Orange, Ca Member No.: 178 |
onced you get a good alignment, toe changes are easy. You need a real good baseline (you gots already) then all you have to do is to mark your tie rod thingies real good and make very small, even changes. If you are anal enough you will keep close enough records so that you can always go back.
I figure about 1/16 of a turn at a time should be good for testing. |
Lo-Fi Version | Time is now: 19th May 2024 - 12:15 PM |
