2.0 Engine Analysis, Taking it apart |
Carlitos Way |
Nov 8 2006, 07:09 PM
I did it MY WAY Group: Members Posts: 1,337 Joined: 14-September 04 From: Simi Valley, CA Member No.: 2,757 Region Association: Southern California |
Thanks for the words of caution. Amazingly enough, I have been labeling everything and trying to keep it all smooth and organized. I am planning on sending everything out to be machined... heads, bottom end, etc. Still haven't decided on crankcase (re-machined or new) and cam. I'm suspecting the Webcam 86a may be my best bet if I stay with 96 MM pistons/cylinders. I don't plan on changing the crank/stroke unless I have to... and I am hoping to have the case align bored and all machine work done by a reputable company.... speaking of which I'm happy to accept suggestions on a machine shop near the San Fernando Valley. I am also thinking about sending the heads to RIMCO... that's probably a ways down the road, as I plan on doing the bottom end, and waiting until I have the $$$ to proceed with the heads. I think since I have the 912E heads, I will have to get them welded for the air breather tube. Not sure if I want to use a smaller spark plug, but it sounds like a reasonable modification "while we're at it."
Bleyseng |
Nov 8 2006, 07:38 PM
Aircooled Baby! Group: Members Posts: 13,035 Joined: 27-December 02 From: Seattle, Washington (for now) Member No.: 24 Region Association: Pacific Northwest |
Thanks for the words of caution. Amazingly enough, I have been labeling everything and trying to keep it all smooth and organized. I am planning on sending everything out to be machined... heads, bottom end, etc. Still haven't decided on crankcase (re-machined or new) and cam. I'm suspecting the Webcam 86a may be my best bet if I stay with 96 MM pistons/cylinders. I don't plan on changing the crank/stroke unless I have to... and I am hoping to have the case align bored and all machine work done by a reputable company.... speaking of which I'm happy to accept suggestions on a machine shop near the San Fernando Valley. I am also thinking about sending the heads to RIMCO... that's probably a ways down the road, as I plan on doing the bottom end, and waiting until I have the $$$ to proceed with the heads. I think since I have the 912E heads, I will have to get them welded for the air breather tube. Not sure if I want to use a smaller spark plug, but it sounds like a reasonable modification "while we're at it." Len at HAM or Adrian at Headflowmasters for head work...guess you didn't see the head thread a couple of weeks ago...... |
Cruzing |
Nov 8 2006, 07:51 PM
Member Group: Members Posts: 214 Joined: 23-October 06 From: San Diego Member No.: 7,082 |
I just went through a 2.0 rebuild with a very good porsche mechanic, he warned and I found out that the 2.0 heads are going to be a problem, they do not make new ones anymore so all you get are remanufactured ones, I have gone through 4 heads failing now, valve seats slaping out on the exh. side, I gave up and now installing a 6 cyl...
good luck on your project, hope you have better luck than I did... (IMG:style_emoticons/default/smile.gif) |
dmenche914 |
Nov 8 2006, 09:43 PM
Senior Member Group: Members Posts: 1,212 Joined: 27-February 03 From: California Member No.: 366 |
probably you will then need to have all the seats redone by someone that knows what they are doing. a dropped seat can ruin you engine, and since they are unknown?????? I would assume the seats can be done right, but you got to find someone that does them right.
i have heard one right way is to cool the seats, and heat the head, and have it all machined so that it is a really big interfernce fit (when at room temp). I have heard of LN2 used to cool the seats, and use a small oven to warm up the heads. this is best left to someone that will warrent them, if they stand behind the work, and have good references you should be ok. if any ole machine shop just trries to press new seats in at room temp, you proabably are going to have trouble later. sorry i don't have recommendation, but that is what i have heard |
Cruzing |
Nov 8 2006, 10:08 PM
probably you will then need to have all the seats redone by someone that knows what they are doing. a dropped seat can ruin you engine, and since they are unknown?????? I would assume the seats can be done right, but you got to find someone that does them right. i have heard one right way is to cool the seats, and heat the head, and have it all machined so that it is a really big interfernce fit (when at room temp). I have heard of LN2 used to cool the seats, and use a small oven to warm up the heads. this is best left to someone that will warrent them, if they stand behind the work, and have good references you should be ok. if any ole machine shop just trries to press new seats in at room temp, you proabably are going to have trouble later. sorry i don't have recommendation, but that is what i have heard Finding a good shop to do it with warranty, tough one to find. I am in San Diego, there is only one place to go, they would not give a warranty due to past problems with the heads, they would review the failure, then determine workmanship or not failure, you know what there findings would be,, my wallet in there hand... (IMG:style_emoticons/default/smile.gif) |
Carlitos Way |
Nov 9 2006, 10:26 AM
Thanks for the words of caution. Amazingly enough, I have been labeling everything and trying to keep it all smooth and organized. I am planning on sending everything out to be machined... heads, bottom end, etc. Still haven't decided on crankcase (re-machined or new) and cam. I'm suspecting the Webcam 86a may be my best bet if I stay with 96 MM pistons/cylinders. I don't plan on changing the crank/stroke unless I have to... and I am hoping to have the case align bored and all machine work done by a reputable company.... speaking of which I'm happy to accept suggestions on a machine shop near the San Fernando Valley. I am also thinking about sending the heads to RIMCO... that's probably a ways down the road, as I plan on doing the bottom end, and waiting until I have the $$$ to proceed with the heads. I think since I have the 912E heads, I will have to get them welded for the air breather tube. Not sure if I want to use a smaller spark plug, but it sounds like a reasonable modification "while we're at it." Len at HAM or Adrian at Headflowmasters for head work...guess you didn't see the head thread a couple of weeks ago...... I'm sure we've all heard of Len... but Who's Adrian? does anyone have any comments or experience? where are they both located? |
G e o r g e |
Nov 9 2006, 10:31 AM
Dr Group: Members Posts: 1,905 Joined: 20-September 05 From: Southern Cal Member No.: 4,832 Region Association: None |
if you listen to jakes radio show this weeks and last, you would have heard the head special that is still in effect from len, if i needed heads done right now thats the path i would takelisten hear (IMG:style_emoticons/default/beerchug.gif)
Carlitos Way |
Nov 9 2006, 10:51 AM
Thanks... I'll have to make some time to listen to it today when I get home from work.
Nov 9 2006, 12:25 PM
914 Idiot Group: Members Posts: 14,991 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
Adrian == Headflow Masters, AKA Audirac. It looks like his website is gone, now. I think he's in the SD area...
--DD |
Carlitos Way |
Nov 9 2006, 08:23 PM
Some more pictures:
Carlitos Way |
Nov 9 2006, 08:25 PM
It's not so hard to take apart.... so far... I'm wondering if the uneven discoloration is normal? Darker on the sides than on the front and back (My terminology still sucks)
Carlitos Way |
Nov 9 2006, 08:27 PM
Another view of the pistons.
Carlitos Way |
Nov 9 2006, 08:53 PM
Here's a picture of one of the heads. Looks pretty clean, even though I didn't spend much time looking at it. The other head has a faint "bruce" printed on the inside. I'm guessing these heads were worked on recently.
Carlitos Way |
Nov 9 2006, 08:55 PM
Going a little out of order here.
Carlitos Way |
Nov 9 2006, 08:57 PM
After removing the oil pump. I wish I knew how to tell if this oil pump is good... or if I should go with a different oil pump. My thought is I would like to go with an external oil cooler when I rebuild, but I'm not sure how to plumb it.
Carlitos Way |
Nov 9 2006, 08:58 PM
So this is what it looks like inside!!!
Carlitos Way |
Nov 9 2006, 08:59 PM
Finally got it off the engine stand. Had to get the kids to unbolt it while I put it on the work table. Hopefully the plastic top won't be a problem when i rebuild.
Carlitos Way |
Nov 9 2006, 09:00 PM
I'm getting ready to take this case apart, but before I do, I'm wondering if I need to remove the studs, or if I should leave them on for now. I'm also wondering which side should go "down" when I finally open the case (after I find all 20 bolts)
Carlitos Way |
Nov 9 2006, 09:21 PM
I decided to take a couple of extra pictures. This is the left rear cylinder. Some day I will learn which cylinder number it is. The other pistons and cylinders look pretty much the same.
Carlitos Way |
Nov 9 2006, 09:22 PM
Reverse view. I'm wondering... can someone explain the different coloration? Is that "blow by" that causes the piston to turn dark on the sides? poor rings?
Lo-Fi Version | Time is now: 7th June 2024 - 11:23 AM |
