> wear your safety equipment ..., while working on the car ...
post Nov 9 2006, 09:07 PM
Resident German
so, i went to mcmark's shop today to work on my car. mostly prep work for the engine test-fit.
lots of cutting sheetmetal and grinding down spotwelds etc. then on to cutting out the /4 motor mounts with the plasma cutter.
i *thought* i had it all covered, safety wise, got the goggles, gloves, noise protection ...
spent about 5 hours cutting & grinding.
then, on my drive home, it felt like i had a sunburn on my arms, but i couldn't really see anything.
so after i got home, i take a shower and now i can clearly see that both of my forearms are *covered* with thousands(!) of tiny burn marks! (IMG:style_emoticons/default/icon8.gif)
should have worn something with long sleeves, damm 914club t-shirt ...
(IMG:style_emoticons/default/headbang.gif) Andy
2 Pages V < 1 2
Replies(20 - 33)
URY914
post Nov 10 2006, 09:05 AM
Post #21
QUOTE(Andyrew @ Nov 10 2006, 06:46 AM) *
Paul..
Those masks acutally are nice..
used one for about 2 months (for hours daily..) without any fail.. Actually it was TOO sensitive.. any little light and it would darken on you..
How in the world do you know that piece of crap is protecting your eyes? It can be burrning a hole in your retnias and you don't know it until you go to the doctor for your yearly eye exam and he sees it. There are ANSI or ECE specs that all helmets must meet. Good helmets cost good money for a reason. Sorry, I'm not taking the chance.
ClayPerrine
post Nov 10 2006, 12:22 PM
Post #22
Even with the proper equipment, you need to be careful.......
Years ago I was installing sway bars on Betty's 914 when a red hot piece of metal landed right on the crotch of my jeans. I didn't know it, and it proceeded to burn through the jeans, through my underwear, and put a nasty second degree burn on a very "sensitive" part of my anatomy. (IMG:style_emoticons/default/pinch.gif) From experience, it is impossible to bandage that part of the male anatomy, and it hurt like hell for weeks until it healed.
And before anyone asks.... I DO NOT HAVE ANY PICTURES and I will not show you the scar!
I got out there after treating the burn and finished the sway bar install. The welds are still there after close to 20 years.
LvSteveH
post Nov 10 2006, 12:26 PM
Post #23
I put the Poor in Porsche
QUOTE(ClayPerrine @ Nov 10 2006, 10:22 AM) *
So is the scar (IMG:style_emoticons/default/chairfall.gif)
ClayPerrine
post Nov 10 2006, 12:35 PM
Post #24
QUOTE(LvSteveH @ Nov 10 2006, 12:26 PM) *
And the wife too....
Post #25
Resident German
QUOTE(LvSteveH @ Nov 10 2006, 10:26 AM) *
and i bet the memory of that event has been burnt into your brain for the rest of your life as well ...
(IMG:style_emoticons/default/av-943.gif) Andy
John
post Nov 10 2006, 12:46 PM
Post #26
member? what's a member?
My thoughts exactly.
I tried one of the "auto darkening" helmets (an expensive one at that) about a week ago. (Had to do some welding on a jobsite and that is what was available to me.)
I couldn't get used to it. I kept flipping the hood up and flipping it back down prior to striking the arc. Anyway, I didn't get any flash (welded for probably 6 hours).
I still can't bring myself to buying one of those things.
20 years ago, I burned my eyes and had to drive myself to the eye doctor for eyedrops. (The early morning sun really hurt the eyes). After I healed from that, I went and bought a new helmet with a large (4x5) gold lens (shade 11) and have been using it without issue ever since.
I can't stand getting anything in or near my eyes to this day (which is why I don't wear contact lenses).
Like the saying goes, if you have a $10 head, then buy a $10 helmet.
jd74914
post Nov 10 2006, 02:30 PM
Post #27
Its alive
Niether my Dad nor I like the autodarkening helmets. We don't feel that they react quickly enough to adaquately protect your eyes. I would rather flip down a hood and know that my eyes are perfectly safe than rely on a battery powered "machine" to do it for me.
Brett W
post Nov 10 2006, 03:01 PM
Post #28
I agree I am not a big fan of autodarkening helmets either. If you block the light sensors you will get flashed anyways. Can't stand that. I like my manual helmet, flip it down and there is no flash.
If I am tacking something I use a gloved hand to shield my eyes, just put it between the gun and my eyes. Works great and fast.
andys
post Nov 10 2006, 03:33 PM
Post #29
What's interesting to me, is how little safety is practiced on some of the hot rod/chopper shows when it comes to welding (and other general saftey precautions). I believe it sends a really bad message to those starting out. Every watch Paul jr on Am. Chopper? I'd fire his ass in a heartbeat; really lousey safety practices. On the other hand, Jesse Combs (a young female welder/fabricator for those that don't know) on Extreme 4X4 (I think) always wears the approprite safety gear; at least so far. I've had a 'V' neck burn that discolored and damaged my skin some 20 years ago. Yup, shirt was not buttoned all the way up. Only recently did a dermatologist give me a potion that seems to be getting rid of it quite nicely.
I've managed tool and die, and prototype machine shops for many years. It always amazes me when I see experienced machinists stick their face close to a milling cutter without eye protection. Seems obvious, but you'd be surprised with how often it happens.
Andys
sgomes
post Nov 10 2006, 04:29 PM
Post #30
Electric Member
Actually those self darkening helmets are ALWAYS protecting your eyes. The base glass blocks the harmful (read - sunburning) UV rays. The auto darkening is only blocking the super bright (but not damaging) visible spectrum. Yes if it didn't work you would get flash blindness. It's the same as that spot you see in front of your eyes from a flash. That is just saturation and is not damaging.
By the way, that said, UV damage to your retinas is CUMULATIVE. It's NOT the same as getting a sunburn on your skin. The damage EVEN SMALL EXPOSURES adds up over time. I design UV lasers for a living. We've been extensively trained on this subject. Sometimes the hard way. (IMG:style_emoticons/default/ohmy.gif)
Our training quote is: "Don't look directly at the laser with your remaining good eye."
SLITS
post Nov 10 2006, 05:57 PM
Post #31
"This Utah shit is HARSH!"
3 days with eyes covered (after a hospital visit) in a Louisana Motel after welding with a buzz box and the wrong goggles --- very painful experience.
Have you ever tried eating pancakes by Braille? Very sticky
URY914
post Nov 10 2006, 06:26 PM
Post #32
QUOTE(sgomes @ Nov 10 2006, 02:29 PM) *
That's the thing about bad helmets. You don't realize your eyes are being damaged. When you burn your skin you see it, feel it and it grows back (sometimes). With eye damage you don't SEE it coming. Get it...SEE it coming. (IMG:style_emoticons/default/laugh.gif)
PORobinSCHE
post Nov 10 2006, 11:18 PM
Post #33
i wear my safety glasses most of the time when working. but that's because at my age i need a little help. the glasses have +1.50 readers on the bottom! (IMG:style_emoticons/default/beerchug.gif)
AvalonFal
post Nov 11 2006, 12:24 PM
Post #34
And don't forget a mask/respirator, too. Cutting thru rust, metal, paint, years of crud and dirt without breathing protection can do a job on your sinuses and lungs. Who knows what's in that stuff after 30+ years?? I wear a mask/respirator until I'm sure the area I'm working on is clean.
2 Pages V < 1 2
- Lo-Fi Version Time is now: 11th July 2025 - 05:52 AM
