Accelerator pump jets drip., Makes my exhaust backfire/pop. |
LowGT |
Nov 17 2006, 07:33 PM
1.8 and Proud! Group: Members Posts: 583 Joined: 2-October 05 From: Wylie, TX Member No.: 4,904 Region Association: Southwest Region |
I have weber 44IDF's on my 2.0 and I noticed the accelerator jets on one of them drip while the car idles. The car also gives a pop through the exhaust, almost a backfire but not quite. The valves are adjusted and the timing is set at 27 degrees, so I think the drips are causing my problems.
Are these drips a indicator of bad float adjustment? How do I stop them? |
SGB |
Nov 17 2006, 08:29 PM
First check at the carb base on the shaft between the barrels where the cam that moves the pump arm lives. Spray some cleaner and wd-39 to see if there is crap hanging it up. What haps with my 40 idf is that the little metal wheel at the end of that arm gets all gommed up...
Lo-Fi Version | Time is now: 15th May 2024 - 01:32 PM |
