how do you attach liscence plate to front bumper? |
mattp |
Nov 24 2006, 12:16 PM
Member Group: Members Posts: 257 Joined: 22-November 06 From: westchester NY Member No.: 7,252 |
I have a 75 914, how do I attach the liscence plate tot he fornt bumper? It has a german plate on there now and the holes are too close for an American plate. thanks,Matt
Cap'n Krusty |
Nov 24 2006, 12:41 PM
You use a 914 front license plate bracket. There must be a few floating around here. The bracket bolts to the holes in the bumper, the plate to the bracket. The Cap'n
Krieger |
Nov 24 2006, 12:45 PM
Advanced Member Group: Members Posts: 4,711 Joined: 24-May 04 From: Santa Rosa CA Member No.: 2,104 Region Association: None |
Behind the rubber is a thick steel bumper. Mine was drilled and mounted using the top lp screw holes. I removed it though. Or you could get a front lp bracket. It mounts in the two recessed holes front and center. It is different than the rear bracket.
Lo-Fi Version | Time is now: 17th May 2024 - 03:17 PM |
