Love having my pics back! 915 shift setup part 5 |
Brad Roberts |
Nov 28 2006, 12:41 AM
We were going over Erik Madsen's Hewland setup and I was thinking about ONE other way that I had seen the 915 shifter mid engine (before WEVO)
Thought I would share this. I know the owner of the car (many of you will recognize it) I'm going to show two different setups in this thread (if not 3) B Attached image(s) |
Brad Roberts |
Nov 28 2006, 12:42 AM
The last shot above is a pic of the Hewland Erik runs in his SCCA production car. This pic clearly shows how his linkage is connected.
B |
Brad Roberts |
Nov 28 2006, 12:45 AM
The shots of the Yellow 914:
he has to change the motion at least one time.. so he moved the shift rod on the shifter from the typical "bottom" setup to the middle setup. Early 914's change motion at the firewall with a similar link at the firewall. Most open wheeled cars change the motion at the shifter like he did in the pics above. B |
DanT |
Nov 28 2006, 12:47 AM
Brad, is the top car Ted Hammer's car? He did alot of developement work on his "frankenshifter" and then got together with Hayden to make the wevo unit.
I instructed Ted at Laguna years ago after he just got the car finished... |
Brad Roberts |
Nov 28 2006, 01:08 AM
Yes! Ted's car and a shot of the purple people eater
B |
roadster fan |
Nov 28 2006, 03:49 AM
Project Frankenstein !!!!!!!! Group: Members Posts: 1,009 Joined: 24-November 05 From: Aptos, CA Member No.: 5,184 Region Association: Northern California |
Is this a jack point? I love that idea! (IMG:style_emoticons/default/smile.gif)
Attached File(s) tranny_jack_point2.bmp ( 138.12k ) Number of downloads: 55 |
Brad Roberts |
Nov 28 2006, 10:43 AM
Yes it is. Add an arrow on the bumper pointing to it and you are all set!
B |
groot |
Nov 28 2006, 11:21 AM
Dis member Group: Members Posts: 894 Joined: 17-December 03 From: Michigan Member No.: 1,444 |
Very cool pics, Brad. Thanks!!!
More ideas to ponder.......... |
Brett W |
Nov 28 2006, 11:24 AM
I am guessing the bottom one is Blakewell's car? Does he even get out to your area? I know he doesn't run much anymore because of the cost.
Brad Roberts |
Nov 28 2006, 12:06 PM
Come on.. Blakewell has a Hewland!... not a 915!
I always forget this "Purple" 914 owners name.. Dave.. Dave.. something. B |
race914 |
Nov 28 2006, 01:00 PM
73 914-4 Group: Members Posts: 1,006 Joined: 31-October 05 From: Nipomo, California (Central Coast) Member No.: 5,027 Region Association: Central California |
DanT |
Nov 28 2006, 02:42 PM
Come on.. Blakewell has a Hewland!... not a 915! I always forget this "Purple" 914 owners name.. Dave.. Dave.. something. B Evans In GGR he was known as "Super" Dave Evans (IMG:style_emoticons/default/biggrin.gif) |
Brad Roberts |
Nov 28 2006, 03:18 PM
That is him!!
I always forget Dave's last name for some reason. Great guy! Super nice. I think he lives in Campbell now. I know he built the dyno room that S-Car-Go uses back a few years ago. B |
Brad Roberts |
Nov 28 2006, 07:21 PM
Ahhh yes!! the money shot!!
Best shot of how the Hewland works (early) B Attached image(s) |
Randal |
Nov 28 2006, 08:05 PM
Brett W |
Nov 28 2006, 11:43 PM
Damn, I am such a geek. Nevermind.
Brad Roberts |
Nov 29 2006, 01:08 AM
Randal,
Erik and I discussed decent used complete boxes for around $3500 It would require all custom clutch setup (clutch arm) not actual clutch. Custom shift linkage Custom mounts Custom bellhousing adapter.. Benefits: The ability to upshift full throttle with no clutch (if you want) the tranny's are LOUD with straight cut gears. Gearsets are readily available in literally 100's of ratios for all gears. The ability to change gearsets quickly. Tons and tons of good support (Hewland is HUGE) B |
Lo-Fi Version | Time is now: 29th April 2024 - 03:54 AM |
