Hot valve clearance, Ideas? |
redshift |
Nov 13 2003, 03:29 PM
Says it all.
M |
ArtechnikA |
Nov 13 2003, 03:34 PM
QUOTE(redshift @ Nov 13 2003, 01:29 PM) Says it all. should be zero; that's why we set it to something, cold. |
redshift |
Nov 13 2003, 03:38 PM
swood |
Nov 13 2003, 04:07 PM
Senior Member Group: Members Posts: 1,839 Joined: 6-February 03 From: Strong Beach Member No.: 251 Region Association: None |
Yoh!
This is somewhat of a long read, but you probably have the time. (IMG:style_emoticons/default/laugh.gif) http://shoptalkforums.com/viewtopic.php?t=...ighlight=valves Ray discusses how he adjusts his valves HOT. Personally, I don't want to jamb my mitts in there near that hot metal, but that's just me. |
Jake Raby |
Nov 13 2003, 04:19 PM
I do mine the same way, on the dyno, and in my cars. On a 914 its near impossible!
The pushrods I have made run zero lash and have .005-7 when at operating temp. |
john rogers |
Nov 13 2003, 04:21 PM
Senior Member Group: Members Posts: 1,525 Joined: 4-March 03 From: Chula Vista CA Member No.: 391 |
The definitive answer is, Depends on what the cam is ground to have as valve clearances and when they should be set. Things that affect it are push rods (alloy or steel), cam grind, lifter type (type 1 or 4)
cylinder barrel material. |
Lo-Fi Version | Time is now: 8th May 2024 - 05:41 PM |
