Thanks Mueller!, I got the trailing arm back! |
Jeffs9146 |
Nov 13 2003, 06:13 PM
All powder coated and pretty!! I would like to talk to you about your needle bearings! How hard are they to install?
Jeff Attached image(s) |
Brad Roberts |
Nov 14 2003, 02:00 AM
You have to have a press to install the sleave correctly. If you pound it in...you stand a chance of screwing up the area that the bearings need to sit into.
What have you been up too ?? Havent heard from you lately. B |
Jeffs9146 |
Nov 14 2003, 09:21 AM
Hi Brad!
I have been very busy with a new distraction! (IMG:style_emoticons/default/mueba.gif) She is taking up a lot of time! I am more worried about where the needle bearings go than the main bearing! I have not decided if I am ready to go all the way with Mikes stuff yet! If I do, then I have to replace both sides! Can I reuse the Item # 1 in the trailing arm photo? Attached image(s) |
Lo-Fi Version | Time is now: 9th May 2024 - 01:37 AM |
