Rough Or Smooth, Which way do you like it? |
Rough_Rider |
Dec 4 2006, 12:33 PM
Smurf Zone Group: Members Posts: 525 Joined: 16-August 04 From: Beaverton, OR Member No.: 2,547 |
The real question is....
After removing casting marks etc on webers is there any point going to either of these next steps? (1) polished & ported inlet so max air can flow smoothly through venturi's. (2) roughened inlet so air becomes turbulent, improving fuel/air mixture. |
URY914 |
Dec 4 2006, 12:38 PM
I built the lightest 914 in the history of mankind. Group: Members Posts: 120,662 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None |
I couple of years back I asked Jake if he thought polishing the intake manifolds or using the Extrude Hone process would make an improvement. He said to leave the intake's casting rough 'cause the rough surface aids in the fuel/air mixture.
Crazyhippy |
Dec 4 2006, 12:46 PM
Insert witty comment here... Group: Members Posts: 1,659 Joined: 28-July 05 From: Home of the Coyotes, AZ Member No.: 4,493 Region Association: None |
Between the fuel inlet and the valves stays rough. pre fuel, and exhaust both can be polished smooth.
BJH |
J P Stein |
Dec 4 2006, 03:35 PM
Irrelevant old fart Group: Members Posts: 8,797 Joined: 30-December 02 From: Vancouver, WA Member No.: 45 Region Association: None |
So, what's rough....as cast?
Joe Ricard |
Dec 4 2006, 06:01 PM
CUMONIWANNARACEU Group: Members Posts: 6,811 Joined: 5-January 03 From: Gautier, MS Member No.: 92 |
Lo-Fi Version | Time is now: 18th May 2024 - 11:11 AM |
