| joeav8tor |
Dec 4 2006, 03:41 PM
Member ![]() ![]() Group: Members Posts: 408 Joined: 23-January 05 From: mattituck, Long Island NY Member No.: 3,493 |
Hi guys,
I am just wondering if it is possible to do a suby swap and have air conditioning? thanks (IMG:style_emoticons/default/flag.gif) Joe |
| TravisNeff |
Dec 4 2006, 03:51 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,082 Joined: 20-March 03 From: Mesa, AZ Member No.: 447 Region Association: Southwest Region
Sure, why not? You arleady will be cutting the trunk for a radiator, you can put your condenser up front iwith it. You will probably have to fab a mouting bracket if the stock unity will not fit. For inside the car you can use the AC fan assy from another 914.
| fat73 |
Dec 4 2006, 09:12 PM
W9R1 ![]() ![]() Group: Members Posts: 244 Joined: 7-May 05 From: tampa,fl Member No.: 4,043 Region Association: South East States |
Hi guys, I am just wondering if it is possible to do a suby swap and have air conditioning? thanks (IMG:style_emoticons/default/flag.gif) Joe Been there, done that, got the tee shirt (and the A/C). http://community.webshots.com/user/fat73 look at the conversion album. Ed aka W9R1 Underdash evaporator unit with heat (IMG:http://thumb19.webshots.net/t/46/46/3/18/23/2278318230076795939bsAaUM_th.jpg) and heat control (uses the original cable feed for heater box flaps) (IMG:http://thumb19.webshots.net/t/38/39/6/12/72/2010612720076795939tEhRZB_th.jpg) AC compressor (stock) on engine (IMG:http://thumb19.webshots.net/t/59/59/7/10/19/2030710190076795939abxCLB_th.jpg) AC Condenser is in front of radiator underneath aluminum cover (IMG:http://thumb19.webshots.net/t/34/35/8/80/32/2122880320076795939jgizNP_th.jpg) |
| joeav8tor |
Dec 5 2006, 09:23 AM
Hi guys, I am just wondering if it is possible to do a suby swap and have air conditioning? thanks (IMG:style_emoticons/default/flag.gif) Joe Been there, done that, got the tee shirt (and the A/C). http://community.webshots.com/user/fat73 look at the conversion album. Ed aka W9R1 Underdash evaporator unit with heat (IMG:http://thumb19.webshots.net/t/46/46/3/18/23/2278318230076795939bsAaUM_th.jpg) and heat control (uses the original cable feed for heater box flaps) (IMG:http://thumb19.webshots.net/t/38/39/6/12/72/2010612720076795939tEhRZB_th.jpg) AC compressor (stock) on engine (IMG:http://thumb19.webshots.net/t/59/59/7/10/19/2030710190076795939abxCLB_th.jpg) AC Condenser is in front of radiator underneath aluminum cover (IMG:http://thumb19.webshots.net/t/34/35/8/80/32/2122880320076795939jgizNP_th.jpg) NICE WORK! thanks for the pics, looks professional...I enjoyed the album shots. Joe |
| Crazyhippy |
Dec 6 2006, 03:13 PM
Insert witty comment here... ![]() ![]() ![]() Group: Members Posts: 1,659 Joined: 28-July 05 From: Home of the Coyotes, AZ Member No.: 4,493 Region Association: None |
It is also possible to keep everything behind the dash, and blow through the factory vents. It's MAJOR custom work though.
BJH |
| andys |
Dec 6 2006, 03:28 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,165 Joined: 21-May 03 From: Valencia, CA Member No.: 721 Region Association: None
Fat73,
Who's AC evaporator unit is that? Is it heat and cool? Thanks, Andys |
| fat73 |
Dec 6 2006, 05:58 PM
Lo-Fi Version | Time is now: 13th February 2026 - 07:56 PM |
