Howard |
Incontin(g)ent Member ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 5,785 Joined: 24-July 03 From: Westlake Village, CA Member No.: 943 Region Association: None ![]() ![]() ![]() |
All of a sudden I can't delete some read items from the inbox. Get message 'This message could not be deleted'. ???
Part Pricer |
Believe everything I post ![]() ![]() ![]() Group: Benefactors Posts: 1,825 Joined: 28-December 02 From: Danbury, CT Member No.: 35 ![]() ![]() |
You most likely have a corrupted delete.dbx file. Try this: Close Outlook Express. Search for "delete.dbx" on your PC. I'm not sure exactly where this is anymore. But it should be somewhere under Documents and Settings. Rename this file to something else like"delete.bak" Restart Outlook Express. This will create a new delete.dbx file and you should be OK. |
KaptKaos |
Family ![]() ![]() ![]() ![]() Group: Members Posts: 4,009 Joined: 23-April 03 From: Near Wausau Member No.: 607 Region Association: Upper MidWest ![]() |
When was the last time you emptied your deleted items folder?
Right click on your deleted items folder and select Empty. That might do the trick too. |
Part Pricer |
I was close. Here is a link to the Microsoft KB article on this http://support.microsoft.com/kb/312348/en-us |
Howard |
I was close. Here is a link to the Microsoft KB article on this http://support.microsoft.com/kb/312348/en-us Good stuff. Problem is I don't want to lose my deleted items. There's business stuff in there that I may need to reference. If all else fails I'll just create a backup file. Is there really a space limit on deleted messages? Can it be changed? |
bd1308 |
Sir Post-a-lot ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,020 Joined: 24-January 05 From: Louisville,KY Member No.: 3,501 ![]() |
I'm sorry, I'm not understanding how you plan to keep "Important Business Stuff" in your deleted items folder?
Get them outta there quick. |
hmeeder |
Dante's Sportscar ![]() ![]() Group: Members Posts: 352 Joined: 21-November 04 From: San Diego, CA Member No.: 3,154 ![]() |
Howard- Create a folder for your Important Business Stuff in OE (right click "Local Folders" then "New Folders" and name it, oh, "Important Business Stuff") Drag and drop the stuff you want to keep from the deleted items folder into your new folder. Then empty your deleted items folder. Too much crappola just gums up the works (mentally if nothing else.) Keep what you need, get rid of what you don't. My $.02 |
KaptKaos |
Good stuff. Problem is I don't want to lose my deleted items. There's business stuff in there that I may need to reference. (IMG:style_emoticons/default/alfred.gif) (IMG:style_emoticons/default/huh.gif) (IMG:style_emoticons/default/idea.gif) (IMG:style_emoticons/default/poke.gif) (IMG:style_emoticons/default/slap.gif) Right, so you should make a folder and copy those items into it. And stop doing that too. |
Howard |
Thanks guys. On the right track. 'deleted items' got infected or corrupted so I'm in the process of moving those items to a safe spot for future reference. Then I can follow Paul's fix tip to delete and replace 'deleted items' or just reinstall Outlook Express.
Just FYI why it's important for me to keep these, here's an example... Someone wants to save money on their policy and increase deductibles. We want this in writing in case he has a claim and 'forgets' he ordered the change. I print the email and put it in his file, but as a backup, still save all deleted items. |
Joe Bob |
Retired admin, banned a few times ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 17,427 Joined: 24-December 02 From: Boulder CO Member No.: 5 Region Association: None ![]() |
Create an "asshole file"....drag and drop them in there....you should have a seperate file for me.....
Deleted messages should be for stuff you don't wanna see. It's there so that if you DO delete something you wanna keep you can get it back....shouldn't be for storage. |
turbo914v8 |
Member ![]() ![]() Group: Members Posts: 373 Joined: 26-July 03 From: Canada Member No.: 952 ![]() |
OK here you go. What you really need to do is creat a FileName.pst file to keep the important e-mails. follow the link for the answers to all your Outlook questions.
Outlook tips and answers |
Dr. Roger |
A bat out of hell. ![]() ![]() ![]() ![]() Group: Members Posts: 3,944 Joined: 31-January 05 From: Hercules, California Member No.: 3,533 Region Association: Northern California ![]() |
This utility has saved my behind on more than one occasion.
The Inbox Repair Tool is located in the C:\Program Files\Common Files\System\Mapi\1033\NT directory of any system that’s running Windows 2000 or Windows XP. The tool’s filename is Scanpst.exe. Dr. Rog |
effutuo101 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,736 Joined: 10-April 05 From: Lemon Grove Member No.: 3,914 Region Association: Southern California ![]() |
(IMG:style_emoticons/default/agree.gif) to both the above posts
That or set up to save a copy of the email in your sent items. This will also max you out for your email box limits, but you usually get a couple of months in before performance goes way down. |
Lo-Fi Version | Time is now: 9th July 2025 - 08:29 AM |
