> Setting End Play, Rear main seal still in
Krieger
post Dec 10 2006, 10:07 AM
I changed to a newer lighter flywheel. I have replaced the rear main seal only 3k ago, and it doesn't leak. Can I accurately set end play with seal in? (IMG:style_emoticons/default/confused24.gif) Yes I am a little lazy, but these can be a pain to install w/o leaks imho.
DNHunt
post Dec 10 2006, 10:14 AM
914 Wizard? No way. I got too much to learn.
I think you can check it but if you have to change shims you'll have to pull it. By the way an old stub axle is just the right diameter to use to drive a new one in. It makes it easier to drive it in straight.
McMark
post Dec 10 2006, 11:28 AM
914 Freak!
And thanks for the installer tip Dave! (IMG:style_emoticons/default/thumb3d.gif)
So.Cal.914
post Dec 10 2006, 01:21 PM
"...And it has a front trunk too."
QUOTE(Krieger914 @ Dec 10 2006, 08:07 AM) *
IMHO if you don't do it, and it leaks you will have to pull it all apart right after
you pull your own foot out of your butt. They are not that hard to change
and not very expensive. But that is me.
- Lo-Fi Version Time is now: 8th July 2025 - 01:42 PM
