Help with cutting holes for -6 oil tank., would like to cut holes now while looking for an oil tank. |
jj83118 |
Jan 6 2007, 12:22 PM
Newbie Group: Members Posts: 33 Joined: 12-May 05 From: Colorado Springs, CO Member No.: 4,066 Region Association: None |
Help!
I'm in the middle of repairing the longitudinal rust on my 914-6 conversion and I'd like to cut all the required holes for installing a -6 oil tank. I have most of the left rear quarter-panel off and I'd like to cut the holes while I have easy access. I can plainly see where most of the holes should go, but I don't know where to cut the unmarked hole. I could also use some help cutting the required hole in the engine tray sheet metal. Any help is appreciated. Thanks, Jim |
GeorgeRud |
Jan 6 2007, 04:17 PM
Kudos to the Auto Atlanta templates, they were a perfect fit when I cut my conversion. Had the locations and sizes of the holes well laid out.
Only caveat, if you're using an aftermarket tank, you might be best served to wait till you get the actual tank. Use the old adage, measure twice, cut once! |
Lo-Fi Version | Time is now: 17th May 2024 - 02:50 AM |
