Help with cutting holes for -6 oil tank., would like to cut holes now while looking for an oil tank. |
jj83118 |
Jan 6 2007, 12:22 PM
Newbie Group: Members Posts: 33 Joined: 12-May 05 From: Colorado Springs, CO Member No.: 4,066 Region Association: None |
Help!
I'm in the middle of repairing the longitudinal rust on my 914-6 conversion and I'd like to cut all the required holes for installing a -6 oil tank. I have most of the left rear quarter-panel off and I'd like to cut the holes while I have easy access. I can plainly see where most of the holes should go, but I don't know where to cut the unmarked hole. I could also use some help cutting the required hole in the engine tray sheet metal. Any help is appreciated. Thanks, Jim |
Trekkor |
Jan 26 2007, 11:03 PM
I do things... Group: Members Posts: 7,809 Joined: 2-December 03 From: Napa, Ca Member No.: 1,413 Region Association: Northern California |
try this.
I believe Dan Root sent me this a couple of years ago. Worked perfect. I doctored it for clarity. The image needs to be 8.5x11, then print. Line up the tank mount hole with the raised filter console boss on the stock 914-4 inner fenderwell, mark for the new hole and cut. KT Attached image(s) |
Lo-Fi Version | Time is now: 19th May 2024 - 03:57 PM |
