GT metal flares- how to install? |
rfuerst911sc |
Jan 6 2007, 03:27 PM
Advanced Member Group: Members Posts: 2,158 Joined: 4-May 06 From: Dahlonega , Georgia Member No.: 5,980 Region Association: South East States |
Well I signed up for the group buy of GT metal flares so now I want to know how to install these. I have a mig welder and am a fair welder so my intention is to install these myself. Once you cut the fenders ( hopefully correctly ) you line the flares up and tack them in place right? Once tacked do you run a continous bead or do you do spaced welds? Once tacked/welded then you grind the welds flush? And then do your skim coats of bondo to finish? Any online forum how to's on this? I know that the least amount of heat is good to keep warping to a minimum but any tips are appreciated. Thanks (IMG:style_emoticons/default/beerchug.gif)
IronHillRestorations |
Jan 6 2007, 06:18 PM
I. I. R. C. Group: Members Posts: 6,719 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None |
Here's what it looks like after it's cut and tacked all the way around. The small tack beads are as large as I weld. I just make small beads all the way around, using a copper spoon on the back of the weld seam to defer heat and keep from blowing through.
Attached thumbnail(s) |
Lo-Fi Version | Time is now: 18th May 2024 - 08:06 PM |
