Tool for cutting metal discs?, Nibbler? Shears? Laser? |
Air_Cooled_Nut |
Nov 18 2003, 10:35 PM
914 Ronin - 914 owner who lost his 914club.com Group: Members Posts: 1,748 Joined: 19-April 03 From: Beaverton, Oregon Member No.: 584 Region Association: None |
What tool do you metal pounders recommend for cutting circles? I welded up the side marker mounting holes and am read to weld in a disc in the large center hole -- don't want to pack that sucker with filler, ya know (IMG:style_emoticons/default/laugh.gif)
BTW, I have very shallow pockets so let's keep costs down (IMG:style_emoticons/default/welder.gif) |
GWN7 |
Nov 18 2003, 11:32 PM
A holesaw without the center drill bit? If you can get one the right size, their cheep.
Nov 18 2003, 11:48 PM
Resident German Group: Admin Posts: 41,644 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
QUOTE(GWN7 @ Nov 18 2003, 09:32 PM) A holesaw without the center drill bit? If you can get one the right size, their cheep. (IMG:style_emoticons/default/agree.gif) what he said ^^^ |
J P Stein |
Nov 19 2003, 03:00 AM
Humm, without a pilot drill, you need to do it in a drill press.
Clamp it down (the sheet metal) on a block of wood VERY well or it will eat you alive. Or: Scribe the diameter out with a compass and cut with L or RH sheet metal shears. File or grind to clean up. Easy. |
GWN7 |
Nov 19 2003, 03:10 AM
What he said.... (IMG:style_emoticons/default/smile.gif)
or if you don't have a drill press put a block of wood under the metal and stand on it. Drill slow. Your shoes can as a guide for the bit. Wear old shoes. If you can't get a hole saw the right size, get one slightly bigger and grind the edge till it fits. |
J P Stein |
Nov 19 2003, 03:14 AM
QUOTE(GWN7 @ Nov 19 2003, 01:10 AM) or if you don't have a drill press put a block of wood under the metal and stand on it. Drill slow. Your shoes can as a guide for the bit. Wear old shoes. I wanna see the video of that operation (IMG:style_emoticons/default/laugh.gif) (IMG:style_emoticons/default/laugh.gif) (IMG:style_emoticons/default/laugh.gif) (IMG:style_emoticons/default/laugh.gif) (IMG:style_emoticons/default/laugh.gif) (IMG:style_emoticons/default/laugh.gif) edit: I hunkered down in my engine compartment with a 1/2 drill motor and a 4 inch hole saw.....cut-out for the oil tank... That thing beat the living dogshit outta me....I think there are some permenent discolorations on my soft pink body from that deal. |
Korijo |
Nov 19 2003, 03:20 AM
[]D o [] o []V[] o []D Group: Members Posts: 1,308 Joined: 16-July 03 From: North Bend, WA Member No.: 914 |
If you drill a hole in a block of wood first (w/ hole saw AND pilot bit), you can clamp the block to the sheet metal, and drill using the hole saw w/out the pilot bit (or a drill press (IMG:style_emoticons/default/wink.gif) ).
JWest |
Nov 19 2003, 07:15 AM
If money is an issue, trade fancy tools for good old fashioned labor.
Just mark a circle with a compass (or a quater and the tip of a knife or whatever) and cut to the line with tinsnips. File to fit. Otherwise, use a fender washer - remove all plating - weld the center hole - and file the outside to fit the fender hole. |
JFJ914 |
Nov 19 2003, 08:06 AM
Senior Member Group: Benefactors Posts: 813 Joined: 13-June 03 From: Alpharetta, GA Member No.: 814 Region Association: South East States |
(IMG:style_emoticons/default/agree.gif) with Korijo
TheCabinetmaker |
Nov 19 2003, 08:23 AM
QUOTE(Korijo @ Nov 19 2003, 03:20 AM) If you drill a hole in a block of wood first (w/ hole saw AND pilot bit), you can clamp the block to the sheet metal, and drill using the hole saw w/out the pilot bit (or a drill press (IMG:style_emoticons/default/wink.gif) ). Use two blocks of wood. Predrill a hole in one with the pilot bit, remove the pilot bit, sandwich the metal between the two blocks, clamp very tightly, and use the predrilled hole for a guide for the hole saw. Spend the money and get a good "BiMetal" bit. It'll last 100 times longer than the $3.00 ones. |
jnp914 |
Nov 19 2003, 08:52 AM
Member Group: Members Posts: 177 Joined: 19-August 03 From: Las Vegas, NV Member No.: 1,046 |
If you do the block of wood/old shoe method, make sure the block of wood is wide enough for your whole foot. I tried it on a 2x4. I lost my balance and fell backwards, obviously faster than I could get the bit out or stop the two handled 1/2 torquemaster beast drill, the metal piece slips out from under my shoe, gets flung off the drill across the garage, bounces off the car hood (not a 914) and imbeds itself into the far (finished) wall.
The wife hears the commotion, comes out and wants to know what the hell is going on and does everything I do lately have to include personal or property damage. "Maybe." |
John Kelly |
Nov 19 2003, 09:04 AM
Senior Member Group: Members Posts: 692 Joined: 1-May 03 From: Moclips WA. Member No.: 640 |
Buy a set of green handled aviation snips... the offset kind. Cut to within a 1/8" of your line first, then do the fine trimming ...which is easier with less material to cut away, file to fit. The offset snips are great. I like the Wiss brand. You can twist them around a very small radius without leaving little daggers if you practice a bit.
John www.ghiaspecialties.com |
mr914 |
Nov 19 2003, 10:19 AM
914 Hillbilly Group: Members Posts: 576 Joined: 11-January 03 From: Lincoln NE Member No.: 131 Region Association: None |
I used blue masking tape from the front side.
I then cut the template out with an exacto knife. I then put the tape template on the sheetmetal. In my case, I called a friend with a plasma cutter. Otherwise, cut close with aviation snips and grind to fit. Good luck. |
Air_Cooled_Nut |
Nov 19 2003, 11:30 AM
QUOTE(vsg914 @ Nov 19 2003, 06:23 AM) QUOTE(Korijo @ Nov 19 2003, 03:20 AM) If you drill a hole in a block of wood first (w/ hole saw AND pilot bit), you can clamp the block to the sheet metal, and drill using the hole saw w/out the pilot bit (or a drill press ;) ). Use two blocks of wood. Predrill a hole in one with the pilot bit, remove the pilot bit, sandwich the metal between the two blocks, clamp very tightly, and use the predrilled hole for a guide for the hole saw. Spend the money and get a good "BiMetal" bit. It'll last 100 times longer than the $3.00 ones. Thanks for the tips! The hole saw should've come to me cuz I have 3 different sizes staring at me on my peg board (IMG:style_emoticons/default/blink.gif) A pilot hole is no biggie because they are quite small AND I can weld that little hole closed quite easily (IMG:style_emoticons/default/blowtorch.gif) Jerry, tell the misses, "Yes, however cars prefer blood when they can get it." |
tmp914 |
Nov 19 2003, 10:44 PM
Newbie Group: Members Posts: 42 Joined: 24-January 03 From: Vernon, NJ Member No.: 193 |
I used tin snips a file and a little time (IMG:style_emoticons/default/beer3.gif)
ppickerell |
Dec 1 2003, 09:44 PM
914 addicted Group: Members Posts: 1,679 Joined: 14-October 03 From: Pleasanton, CA. Member No.: 1,246 |
I just found this thread during a search for korijo story. Send me a drawing and I will laser cut for free for clubmember, you pay for shipping. Am I too late or have you commited a metal mistake?
Dave Bell |
Dec 1 2003, 10:39 PM
Member Group: Members Posts: 234 Joined: 27-November 03 From: Santa Clarita, CA Member No.: 1,398 Region Association: None |
For saving time, use what ever you have handy to trace out and cut out a slightly over size disk and trim to fit on a grinder. You could have it on and tack welded in place in 1/4 the time it takes you to go find or buy the "right" tool and experiment. No matter how perfect the fit you make, your going to be grinding/filing down the extra metal from you welds.
GWN7 |
Dec 1 2003, 10:42 PM
Hi Dave. Still have that engine in the crate. (IMG:style_emoticons/default/beerchug.gif)
Aaron Cox |
Dec 1 2003, 11:01 PM
I smell a classic thread (IMG:style_emoticons/default/smilie_pokal.gif) . what do you do with the side marker pimple's wiring harness?
Korijo |
Dec 2 2003, 01:19 AM
QUOTE(acox914 @ Dec 1 2003, 09:01 PM) I smell a classic thread (IMG:style_emoticons/default/smilie_pokal.gif) . what do you do with the side marker pimple's wiring harness? Use it for CAMP 914 euro turn conversion kit (IMG:style_emoticons/default/wink.gif) QUOTE Send me a drawing and I will laser cut for free for clubmember, you pay for shipping. I could use a set. I'll PM you for details. |
Lo-Fi Version | Time is now: 19th May 2024 - 06:07 AM |
