Loosening striker plate - how much force is okay? |
smontanaro |
Jan 8 2007, 05:57 PM
Senior Member Group: Members Posts: 1,190 Joined: 3-June 05 From: Evanston, IL Member No.: 4,197 Region Association: Upper MidWest |
The right side door on my /6 doesn't close well (doesn't close completely, tends to open at inopportune left-hand moments). There's no sag that I can see. (The car passes the 200lb butt test.) If I understand correctly the trick is to loosen the striker plate screws and adjust it by trial-and-error. Trouble is, if I loosen the screws the plate behind the door jamb that they screw into seems fixed in place. Is that supposed to move? How much persuasion can I apply without damaging something?
Thx, Skip |
Lo-Fi Version | Time is now: 22nd May 2024 - 01:04 AM |
