| markb |
Feb 21 2007, 10:10 PM
914less :( ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,450 Joined: 22-January 03 From: Nipomo, CA Member No.: 180 Region Association: Central California
Uh-oh. (IMG:style_emoticons/default/sad.gif) IIRC, it will be easiest to have 2 people to thread that baby back in, but it's been a really long time since I put one in.
| dyw914 |
Feb 22 2007, 12:51 PM
Member ![]() ![]() Group: Members Posts: 56 Joined: 30-September 03 From: San Gabriel, CA Member No.: 1,211 Region Association: Southern California |
Mark, great thread. I was disassembling my trunk lock last night and noticed there is a rubber?/plastic? gasket between the cylinder and the housing near the top where the key is inserted. I’m guessing it’s used to keep dirt from getting into the lock cylinder. Do you know if this gasket is still available?
David |
| 7TPorsh |
Feb 22 2007, 01:19 PM
7T Porsh ![]() ![]() ![]() ![]() Group: Members Posts: 2,691 Joined: 27-March 06 From: Glendale Ca Member No.: 5,782 Region Association: Southern California
My handles are good...are the lock cylinders available by themselves?
| markb |
Feb 22 2007, 02:21 PM
Mark, great thread. I was disassembling my trunk lock last night and noticed there is a rubber?/plastic? gasket between the cylinder and the housing near the top where the key is inserted. I’m guessing it’s used to keep dirt from getting into the lock cylinder. Do you know if this gasket is still available? David I'm sure you're correct as to thier use, but I have no idea whether they are still available. You might check with our parts folks (GPR, Pelican, etc) to see. |
| markb |
Feb 22 2007, 02:23 PM
| 914Sixer |
Feb 23 2007, 08:54 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,583 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region
The 75-76 steering column requires you to mark and then drill hole to remove pin holding ignition lock. The only place I have seen the demensions is the the factory manuals. Good pictorial.
| bd1308 |
Feb 23 2007, 02:11 PM
Sir Post-a-lot ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,020 Joined: 24-January 05 From: Louisville,KY Member No.: 3,501 |
A dremel makes any key suddenly work.
I took the lazy way out LOL |
| jim_hoyland |
Feb 23 2007, 09:36 PM
Get that VIN ? ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,140 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California
Yup; just learned about this today.Why didthey make that change ? The '74 has a hole.
The 75-76 steering column requires you to mark and then drill hole to remove pin holding ignition lock. The only place I have seen the demensions is the the factory manuals. Good pictorial. |
| markb |
Feb 24 2007, 12:46 AM
Jim, were you able to take any pics you could post?
Yup; just learned about this today.Why didthey make that change ? The '74 has a hole. The 75-76 steering column requires you to mark and then drill hole to remove pin holding ignition lock. The only place I have seen the demensions is the the factory manuals. Good pictorial. |
| markb |
Jun 14 2007, 11:22 PM
I guess it's time for a little update. I finally got around to digging out my 911SC ignition switch, and after a bit of tinkering, I've figured out how to re-key it. Look at the end of this thread for the update.
| orange914 |
Jun 14 2007, 11:43 PM
http://5starmediaworks.com/index.html ![]() ![]() ![]() ![]() Group: Members Posts: 3,371 Joined: 26-March 05 From: Ceres, California Member No.: 3,818 Region Association: Northern California |
not trying to hijack the thread but have a door lock that locks but doesnt unlock. with key turned normally in unlock direction, the screwed on tab on the inner door side "jumps" back to neutral. the screw is tight and moves with tab. like something is releasing internally (IMG:style_emoticons/default/confused24.gif) oh, and it does have a good plastic piece
now back to your regularly schedualed program |
| markb |
Jun 14 2007, 11:47 PM
It sounds like you need to clean & lube everything in the door and the handle. The actuator on the handle is not working the lock mechanism. Either that or your handle itself may be broken (corners rounded).
| orange914 |
Jun 15 2007, 12:23 AM
It sounds like you need to clean & lube everything in the door and the handle. The actuator on the handle is not working the lock mechanism. the handle is out and in hand. the key turns the inner screwed on tab to lock but when turned to unlock it moves a short way and pops back nuetral position. as if internally slipping. the screw is not loose and stays with the tab |
| markb |
Jun 15 2007, 12:27 AM
I bet the edges of the tumbler have rounded off. The actuator (the piece screwed on the end) is probably slipping because of that. Pull the actuator off & look at the edges. You may need a new tumbler.
| markb |
Jun 19 2007, 01:15 PM
OK, hopefully I can now finish this thread.
This is what I've done to re-key a 914-6 (this one is actually a 911) ignition switch. There is a "blind" pin that needs to be removed. I was lucky with this one, in that it was removable without drilling. I talked to a local locksmith, and he advised drilling a small hole next to the pin, and use a small pick or awl to remove it. ![]() Once the pin is removed, the assembly will slide out. ![]() There is a black piece at the front of the assembly that twists off. To remove the tumbler, remove the circlip (kind of a pain in the a$$). ![]() ![]() Now you can re-key it as explained above. ![]() Put it back together & drive that puppy! (IMG:style_emoticons/default/driving.gif) (IMG:style_emoticons/default/driving-girl.gif) |
| dflesburg |
Jun 19 2007, 04:14 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,722 Joined: 6-April 04 From: Warm and Cheerful Centerville Ohio Member No.: 1,896 Region Association: None |
sweet.
| dflesburg |
Jul 6 2007, 12:16 PM
oh, and Thank you
| markb |
Jul 6 2007, 04:20 PM
You're welcome. (IMG:style_emoticons/default/smile.gif)
| JPB |
Jul 6 2007, 06:48 PM
The Crimson Rocket smiles in your general direction. ![]() ![]() ![]() ![]() Group: Members Posts: 2,927 Joined: 12-November 05 From: Tapmahamock, Va. Member No.: 5,107 |
Cool thread! For the record, you can stick your key in that tumbler doohicky and then them brass pieces all get sucked in. If you gerind the remaining brass pieces flush, the key you are using will work. You can us one key for all your cars! If this has been said before then oooh well. Are you using genuin Porsche tools on that or VW? (IMG:style_emoticons/default/beer.gif)
| 96740 |
May 12 2008, 09:05 AM
Member ![]() ![]() Group: Members Posts: 328 Joined: 10-March 08 From: Thousand Oaks, CA Member No.: 8,791 Region Association: Southern California |
Great thread. Someone over at 914.club gave me a link to this. I'm going to probably have to do this to mine here soon. A couple questions... Where do you get the new set of keys? and are they allready cut and do the wafers just work around that?
Roy. |
Lo-Fi Version | Time is now: 4th October 2026 - 02:43 PM |
