| PRS914-6 |
May 12 2008, 09:26 AM
Excellence Magazine Project 914 3.6 ![]() ![]() ![]() Group: Retired Members Posts: 1,278 Joined: 20-May 06 From: Central California Member No.: 6,031 Region Association: None |
If you go to a locksmith and order 1 master kit you will get a new set of keys and new wafers that work for that key. From there you just duplicate the wafers and keys for the remainder of locks. This way you aren't starting off with a worn out key. Good Luck
| 96740 |
May 12 2008, 01:25 PM
Member ![]() ![]() Group: Members Posts: 328 Joined: 10-March 08 From: Thousand Oaks, CA Member No.: 8,791 Region Association: Southern California |
If you go to a locksmith and order 1 master kit you will get a new set of keys and new wafers that work for that key. From there you just duplicate the wafers and keys for the remainder of locks. This way you aren't starting off with a worn out key. Good Luck Thanks for the 411. |
| Lavanaut |
Dec 5 2008, 02:08 PM
Hungry Mind : Thirsty Gullet ![]() ![]() ![]() Group: Members Posts: 916 Joined: 20-June 06 From: Bend, OR Member No.: 6,265 Region Association: Pacific Northwest |
The keys I bought have a 3-digit code on the tag, I'm assuming this relates to the wafer numbers. How though? I'm a bit confused since there are 5 wafers but only 3 numbers on the tag.
Mark, this write-up is killer, I followed it step by step and didn't have any issues. Thanks for putting it together. Reid |
| markb |
Dec 5 2008, 02:13 PM
914less :( ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,450 Joined: 22-January 03 From: Nipomo, CA Member No.: 180 Region Association: Central California
The tag I have here has 4 numbers. Interesting that yours only has 3.
Glad I could be of assistance. |
| nicabr |
Mar 24 2011, 07:11 AM
Newbie ![]() Group: Members Posts: 7 Joined: 8-June 10 From: Sandviken, Sweden Member No.: 11,825 Region Association: Scandinavia |
Great information! (IMG:style_emoticons/default/smilie_pokal.gif) Helped me a lot when I was re-keying my trunk lock yesterday evening.
Nicklas _________________________________ VW-Porsche 914/4 1971 |
| jim_hoyland |
Sep 3 2016, 06:55 AM
Get that VIN ? ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,140 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California
Glad this thread is available ! I just had to use it for rekeying an ignition switch; thanks markb !
| FlacaProductions |
Jun 1 2019, 08:43 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,283 Joined: 24-November 17 From: LA Member No.: 21,628 Region Association: Southern California
I had a new key cut and it seems that it's juuuust a bit "off" - it works fine in one orientation (both in the doors and in the ignition) but if you flip it over, it won't turn - easily, anyway. You can wiggle it around and gently put a little pull on it and it MIGHT turn.
I had a door lock cylinder out at the time and noticed that it doesn't quite suck in the wafers to the point where they are flush with the cylinder. Does this mean the key was cut too far/deep or not far enough? I'm wondering if a little gentle overall filing/smoothing might help but not sure which side to do since it turns one way, but not the other... |
| fiacra |
Jun 1 2019, 11:40 AM
Person.Woman.Man.Camera.TV. = MCI ![]() ![]() ![]() Group: Members Posts: 755 Joined: 1-March 19 From: East Bay Region - California Member No.: 22,920 Region Association: Northern California
Thank you for this tutorial! All seems clearly explained and documented. My question is about key codes.... When I needed a new key for my Honda years ago I just brought the key code in to the locksmith and they cut a new key. I don't have the key code for any of my 914's. Does the key code correspond with the numbers on the wafers? In other words, if I know the sequence and numbers on the wafers can I bring that number to a locksmith and have a new key cut? If so, which end do you start the number from? Anybody have an answer to this?
| bbrock |
Jun 1 2019, 12:03 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,269 Joined: 17-February 17 From: Montana Member No.: 20,845 Region Association: Rocky Mountains
Thank you for this tutorial! All seems clearly explained and documented. My question is about key codes.... When I needed a new key for my Honda years ago I just brought the key code in to the locksmith and they cut a new key. I don't have the key code for any of my 914's. Does the key code correspond with the numbers on the wafers? In other words, if I know the sequence and numbers on the wafers can I bring that number to a locksmith and have a new key cut? If so, which end do you start the number from? Anybody have an answer to this? Yes. I did exactly that a couple years ago. Read the wafer numbers shoulder to tip (thanks @bandjoey for answering that in another thread) and take that and your locks to the locksmith. My locksmith cut a blank from code on one side only and then cut additional blanks on both sides using that master the usual way. He said that would give me a non-working master that would never get worn so I could have additional keys cut the cheap way with confidence. I thought that was a great idea but just two days ago I took two genuine blanks to him with the master. He got a little freaked out over the cost of those blanks so didn't want to trust the master without cutting another cheap blank and testing in the locks. He didn't want to believe me when I told him he had already done that and the master is fine. I appreciate his wanting to be careful but dude, you've already done this. I'm going to take all my keys and locks back in so he can cut the new blanks without having an ulcer. |
| fiacra |
Jun 1 2019, 01:00 PM
Thanks Brent! Appreciate the info. I just came back to this thread after spending some time reading your restoration thread! Impressive......and thank you for documenting everything.
Lo-Fi Version | Time is now: 4th October 2026 - 02:43 PM |
