Suspension and brakes, swaping parts..72 and 75 |
mills914/s |
Jan 12 2007, 12:07 AM
Member Group: Members Posts: 253 Joined: 23-December 06 From: Coeur D'Alene... IDAHO Member No.: 7,363 Region Association: Northern California |
Ok I have a few 914's and was wondering how hard it is to swap all suspension and brakes ...everything off my 75 914 and put them on my 72 what imput can you guys give me whats the same and whats different..Is the brakes the same for both cars can I interchange everything..my 75 has a factory sway bar set up front and rear my 72 has none..
Mueller |
Jan 12 2007, 01:16 AM
you'll need to keep the hubs, struts and calipers from '75 (and ball joints)
the swaybar can easily be installed from the '75 as well....... |
mills914/s |
Jan 12 2007, 01:20 AM
ok thank you ..I plan to strip all the parts I can off the 75 and get rid of it
Chris Pincetich |
Jan 12 2007, 11:24 AM
Make sure the A-arms you use have the mounting tab for the front sway bar drop link. (IMG:style_emoticons/default/wink.gif)
mills914/s |
Jan 13 2007, 12:00 AM
yes they do have the tabs I looked already t..thank you guys
Lo-Fi Version | Time is now: 15th May 2024 - 11:50 AM |
