The Decel Valve Hose Diagram for the 2.0L Djet is Wrong, It doesn't work unless it's hooked up differently |
pbanders |
Jan 20 2007, 05:50 PM
Senior Member Group: Members Posts: 939 Joined: 11-June 03 From: Phoenix, AZ Member No.: 805 |
I made some postings before the "great split" about the decel valve where I asked questions on how it worked. I figured it out, and now I understand why I was confused.
If you look at the hose diagram Dave Darling made for the 2.0L, and I also believe it's the same way in Jeff Bowlsby's diagram, they show the "side" port to the decel valve connected to manifold vacuum, and the larger "end" port connected to the air box. George Hussey of Automobile Atlanta posted a diagram in a thread on the '74 hose configuration that showed it connected oppositely. Which one is right? Turns out George's diagram is correct. As I complained in the earlier thread, I couldn't see how the valve worked when hooked up the way Dave and Jeff's diagrams showed. Not their fault - it's shown that way in the Factory Workshop Manual (see the FI manual, page 0.1-1/3, page 0.1-2/1) and all the other references I've seen. The problem is that if you pull the same manifold vacuum on both the side port (which is on one side of the internal diaphragm) and the skinny end port (which is on the other side of the internal diaphragm), there's no pressure differential to open the valve. It didn't occur to me that the majority of diagrams might be wrong until I saw George's diagram. Now it makes sense - the valve works to limit vacuum if connected so that the large end port is on manifold vacuum and the side port is connected to the air box. Why? Because in this configuration, only the control side of the diaphragm is initially connected to vacuum (actually, it's slightly different from that - a very small area on the other side of the diaphragm is under vacuum where the valve seat for the large end port is located). Once the vacuum is high enough to overcome the internal spring resistance, the valve opens and the intake manifold vacuum is limited. I tested three different decel valves on the bench, two used 914 valves, and a NOS valve I picked up on Ebay for a Volvo D-Jet application. I used a universal plastic tee connector to connect my hand vacuum pump to both the control port and either the large end or side ports of the valves. In each case, if I connected vacuum to both the control port and the side port (same vacuum across both sides of the diaphragm), the valve never opened up to 25 inHg of vacuum. If I connected the vacuum to both the control port and the end port (vacuum differential across the diaphragm), then at an onset vacuum, the valve opened, and I could not pump to a higher vacuum level - the vacuum was limited, as the valve is supposed to do. Both of my 914 decel valves had been "adjusted", so I had no idea of what the correct onset vacuum should be. I recently had my motor rebuilt and did some manifold vacuum level testing. Fully warmed up, at idle, I am running about 10 to 12 inHg of manifold vacuum. If I rev the motor to 3500 rpm and snap the throttle shut, I see a maximum of about 22 inHg of manifold vacuum. The decel valve for the Volvo still has the factory paint mark on it and hadn't been tampered with. Measurements on that valve showed an onset of about 15 inHg. Seemed like a good number, so I adjusted my valve to that level and reinstalled it. Now, when I test it as shown in the Factory Workshop Manual, where you open the throttle to 3500 rpm and snap it shut, you can feel it pull vacuum when the valve opens. I haven't had time to drive it around much since then (working on other problems), but as soon as I do, I'll report on any issues. I may increase the onset vacuum to 18 inHg, as when my motor is cold, it develops about 15 inHg at idle, about the same as the decel valve, and I don't want it to act as a leak. |
John |
Jan 25 2007, 09:09 PM
member? what's a member? Group: Members Posts: 3,393 Joined: 30-January 04 From: Evansville, IN (SIRPCA) Member No.: 1,615 Region Association: None |
QUOTE How could all those diagrams be wrong for so long? Ummm, because nobody ever checked? It seems to me that if this valve does what I am hearing, that it limits the maximum vacuum of the intake plenum/manifold to the set pressure of the decel valve. Did all the D-Jet setups (on other vehicles/makes) have the decel valve? What is manifold pressure (I know it's a vaccuum) at idle? I would assume that the decel valve would be set to activate at a greater vacuum than you would have at idle. Hence the term decel valve. |
pbanders |
Jan 26 2007, 08:37 AM
QUOTE How could all those diagrams be wrong for so long? Ummm, because nobody ever checked? Even though I've got a some data that indicates that the diagrams are wrong, I'm still not 100% convinced, until I hear from a few more people that their decel valve works when connected as I've described. I've been burned before. If it turns out to be true, my guess is that it's probably traceable to a single diagram being wrong 35 years ago. It got copied, that diagram got copied, etc. As you say, nobody went back and checked. When people hooked it up as shown, and actually checked to see if a vacuum was present at the hose when snapping the throttle shut, they didn't feel a vacuum signal. Instead of tracking down the reason, they said "it must be bad" or "that stupid thing isn't needed, anyway", and didn't investigate further. QUOTE It seems to me that if this valve does what I am hearing, that it limits the maximum vacuum of the intake plenum/manifold to the set pressure of the decel valve. Another name for the decel valve is "vacuum limiter". It prevents the manifold vacuum from exceeding a setpoint value. As others in the past have suggested, it also may contribute to the longevity of the MPS, by preventing high vacuum stress on the full-load diaphragm and the bellows. QUOTE Did all the D-Jet setups (on other vehicles/makes) have the decel valve? No, it was an emissions add-on in later years. D-Jet always was a work in progress. QUOTE What is manifold pressure (I know it's a vaccuum) at idle? I just got my engine rebuilt, and took some measurements recently. When cold, manifold idle vacuum is about 15 inHg, dropping to about 12 inHg when fully warmed up. QUOTE I would assume that the decel valve would be set to activate at a greater vacuum than you would have at idle. Hence the term decel valve. Exactly. When the throttle is closed, and the car is moving in gear with the clutch out, the condition is known as "overrun". Manifold vacuum can exceed 20 inHg in overrun. The decel valve limits the vacuum to a value a few inHg more than the idle condition. |
type47 |
Jan 26 2007, 01:03 PM
Viermeister Group: Members Posts: 4,254 Joined: 7-August 03 From: Vienna, VA Member No.: 994 Region Association: MidAtlantic Region |
Another name for the decel valve is "vacuum limiter". It prevents the manifold vacuum from exceeding a setpoint value. As others in the past have suggested, it also may contribute to the longevity of the MPS, by preventing high vacuum stress on the full-load diaphragm and the bellows. i'd like to hear more about this. if this is so, i'll re-install the decel valve, following the corrected diagram of course (IMG:style_emoticons/default/biggrin.gif) |
Lo-Fi Version | Time is now: 19th May 2024 - 12:58 PM |
