> Master cyl, 2 wires?
spunone
post Jan 30 2007, 01:57 PM
Replaced the Master Cyl last nite why is there (IMG:style_emoticons/default/confused24.gif) two connectors and only one male connector on the Master cyl. And I think its the brown wire with the white stripe you use to plug in whats the other brown only wire a ground??
2-OH!
post Jan 30 2007, 02:07 PM
The old MC's had to be grounded through a wire (solid brown)...New style grounds through the case so you only need the Brown/White...Cut or tape back the solid Brown...You don't need it...
2-OH!
TravisNeff
post Jan 30 2007, 02:11 PM
yes, just leave the ground disconnected.
spunone
Great Thanks
dr914@autoatlanta.com
post Jan 30 2007, 02:33 PM
Another question answered by the Tech Tips 700! The early master cylinder switch has two connections to trigger the brake warning light, the late cars have one, the ground for that switch being through the master cylinder. The nice thing about the later switch is that is has an external reset button hidden under the little rubber boot!
sean_v8_914
post Jan 31 2007, 10:50 AM
Chingon 601
Hi Doc. I like your 700 914 tips book...where is that thing
- Lo-Fi Version Time is now: 1st May 2026 - 11:14 PM
