| ws91420 |
Feb 2 2007, 10:42 AM
Yes I have one a Lensley 914 ![]() ![]() ![]() ![]() Group: Members Posts: 2,063 Joined: 10-September 03 From: Ruther Glen,VA (halfway between sticks and civilization) Member No.: 1,137 Region Association: MidAtlantic Region |
The gas pedal on my 73 goes off to side when pressed vs straight back. I have not had time to look at it. What may be the cause and where should I look?
| Eric_Shea |
Feb 2 2007, 10:45 AM
PMB Performance ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 19,304 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
Broken hinge at the base and/or broken throttle crank on the assembly.
| TravisNeff |
Feb 2 2007, 10:46 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,082 Joined: 20-March 03 From: Mesa, AZ Member No.: 447 Region Association: Southwest Region
The hinge is rusting out. you will need to replace the pedal.
I did a lowbucks repair on one of my 914's a long time ago by using a hinge from a hardware store & little cutting and bolted it to the OE floor locationa and drilled 2 holes on the pedal to bolt it to the hinge. |
| DanT |
Feb 2 2007, 10:49 AM
Going back to the Dark Side! ![]() ![]() ![]() ![]() Group: Members Posts: 4,300 Joined: 4-October 04 From: Auburn, CA Member No.: 2,880 Region Association: None |
pedal from a 964 works perfectly and it is less than $10 brand new from Porsche. (IMG:style_emoticons/default/smile.gif)
The mounting holes are spaced slightly differently and require just a bit of adjustment. Otherwise a direct bolt up. |
| Eric_Shea |
Feb 2 2007, 11:23 AM
QUOTE pedal from a 964 works perfectly Got a part number? |
Lo-Fi Version | Time is now: 26th October 2026 - 05:03 AM |
