Why I can't see the World logo in the Headline |
DEC |
Feb 5 2007, 02:25 PM
Senior Member Group: Members Posts: 630 Joined: 10-November 05 From: Rehburg Member No.: 5,104 Region Association: Germany |
I see only a small JPB in the upper left hand corner
Feb 5 2007, 02:32 PM
Resident German Group: Admin Posts: 41,656 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
I see only a small JPB in the upper left hand corner can you see other pictures posted here? avatars? what browser are you using? what skin do you have selected? (IMG:style_emoticons/default/idea.gif) Andy |
DEC |
Feb 5 2007, 03:08 PM
I see only a small JPB in the upper left hand corner can you see other pictures posted here? avatars? what browser are you using? what skin do you have selected? (IMG:style_emoticons/default/idea.gif) Andy Yes I can see all other pics. Only the headline I can't see and the smilie insert is without function My browser is Firefox 2.0.0.1 |
DEC |
Feb 5 2007, 03:13 PM
now I take a look with the MS Explorer all works
but I will not use the f...ing Explorer |
Crazyhippy |
Feb 5 2007, 03:32 PM
Insert witty comment here... Group: Members Posts: 1,659 Joined: 28-July 05 From: Home of the Coyotes, AZ Member No.: 4,493 Region Association: None |
Firefox 2.0.0.1 as well, and can see it fine...
BigDBass |
Dumb Question Champion Group: Members Posts: 1,438 Joined: 11-January 06 From: Chicago (south 'burbs) Member No.: 5,405 Region Association: Upper MidWest |
If you're using the Adblock plugin, see if it's blocking the banner.
(On second thought, that wouldn't explain why it's showing the IPB banner, but I will post it anyway!) (On third and final thought, hit Control+F5 and maybe it will force it to reload the image.) |
DEC |
Feb 5 2007, 04:02 PM
If you're using the Adblock plugin, see if it's blocking the banner. (On second thought, that wouldn't explain why it's showing the IPB banner, but I will post it anyway!) (On third and final thought, hit Control+F5 and maybe it will force it to reload the image.) (IMG:style_emoticons/default/smilie_pokal.gif) Cool Control+F5 fixed the problem Thanks Dan (IMG:style_emoticons/default/beerchug.gif) |
BigDBass |
Feb 5 2007, 04:03 PM
I don't suppose DEC in your case means Digital Equipment Corporation? (IMG:style_emoticons/default/smile.gif)
DEC |
Feb 5 2007, 04:07 PM
I don't suppose DEC in your case means Digital Equipment Corporation? (IMG:style_emoticons/default/smile.gif) Yes that's right, before Compaq takes DEC over in '99 I was working 5 years for DEC at DECSite and NPBU Now I'm working for Cabletron/Enterasys Networks |
BigDBass |
Feb 5 2007, 04:37 PM
I used to use a lot of DEC stuff. VAXes and Alphas. Also used to use Cabletron gear (pre-Enterasys) but now use Cisco.
Cool. (IMG:style_emoticons/default/wink.gif) |
seanery |
Feb 5 2007, 07:05 PM
I had a DEC Alpha...used it as a doorstop for years! (IMG:style_emoticons/default/Jumpy.gif)
DEC |
Feb 6 2007, 07:05 AM
Lo-Fi Version | Time is now: 25th May 2024 - 10:49 AM |
