| trojanhorsepower |
Nov 23 2003, 09:22 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,031 Joined: 21-September 03 From: Marion, NC Member No.: 1,179 Region Association: None |
Is that the ground? Damn!. I finally got time and a place to work on her. I made a frame like Jeroen did and have the car up on jack stands. Maybe I can get this hole filled this week. Thanks to all the tips I am proceeding with confidence (ignorance is bliss). Any last minute advice before I fire up the saws, grinders, and welder?
Thanks -Pete (IMG:style_emoticons/default/welder.gif) Attached image(s)
| Bleyseng |
Nov 23 2003, 09:51 PM
Aircooled Baby! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,036 Joined: 27-December 02 From: Seattle, Washington (for now) Member No.: 24 Region Association: Pacific Northwest |
Make sure to brace everything so it goes back together straight and weld slowly so it doesn't heat up and grow on you. (warp)
Geoff |
| thomasotten |
Nov 24 2003, 08:15 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,570 Joined: 16-November 03 From: San Antonio, Texas Member No.: 1,349 |
Pete:
How are the door jamb clearances with that much rot? -Thomas |
| trojanhorsepower |
Nov 24 2003, 05:37 PM
Drivers side door looks perfect. Passenger side is variable. With the car on the ground it closes up. Now it is open (up in the air w/ no support in the back). I have the doors on still, but I have designed adjustable braces so I should be able to get the spacing right. I figure if I can fix this I can fix anything!
Thanks -Pete PS what are you guys using to measure these gaps? |
| scotty |
Nov 24 2003, 06:10 PM
The Fun Never Stops ![]() ![]() ![]() Group: Members Posts: 773 Joined: 20-May 03 From: Portland. Oregon (SW) Member No.: 718 Region Association: None |
| Jeroen |
Nov 24 2003, 06:54 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,887 Joined: 24-December 02 From: The Netherlands Member No.: 3 Region Association: Europe |
Hey Pete,
Hmmm... doesn't look like fun Before you go any further... weld some braces in the interiour (door gaps) so the car won't sag. It may also be a good idea to support the rear of the car (under the dog-brace at or near the tranny mounts) You can use a couple of scissor jacks (get them at the junk jard) for that. Make sure you don't lift it, just support it. Check the measurements (see the "info" page of this website) to be sure everything is (and stays) straight Good luck! Jeroen |
| trojanhorsepower |
Nov 24 2003, 09:04 PM
Thanks guys
I know it won't be fun, but I am in too deep to back out now! I have done a lot of reading here and other boards, I have read and printed every relavent thread that I could find, so I guess I am as prepaired as I can be. I will make and install my adjustable braces tomorrow if this head cold will let up enough for me to get some work done. I will post pics of the carnage. -Pete |
| trojanhorsepower |
Nov 25 2003, 10:04 PM
Somebody shoot me!
| Brad Roberts |
Nov 26 2003, 12:43 AM
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 19,148 Joined: 23-December 02 Member No.: 8 Region Association: None |
Whoa.. you need to call Bill back at Restoration Design and order his clamshell kit (on sale right now for 270.00 I ordered from him again today).
B |
| Jeroen |
Nov 26 2003, 05:23 AM
| trojanhorsepower |
Nov 26 2003, 02:46 PM
Help!!!
I am about to weld my first fabricated piece in, so I start to measure, and guess what. The “H” dimension is a little over 41”, but the “F” dimension is right on?? How is this possible? If I take the “H” measurement low on the latch depression it is ok, but when I do it the way it looks like I am supposed to (at the upper bolt holes) it is too long. So how do I shrink the door opening with out changing the windshield to roll bar dimension??? (IMG:style_emoticons/default/blink.gif) (IMG:style_emoticons/default/blink.gif) Thanks -Pete |
| Jeroen |
Nov 26 2003, 04:35 PM
As long as the left and right side are the same and the windshieldframe-to-rollbar measurements are in spec, I wouldn't worry about it
cheers, Jeroen |
| Brad Roberts |
Nov 26 2003, 04:38 PM
The piece that the latch bolts too is pretty weak and bends easily. Bend it back. This wont effect the main hoop to targe dimensions. It will effect how the doors closes/opens.
b |
Lo-Fi Version | Time is now: 8th February 2026 - 11:47 AM |
