De taco gotta leaken all ova de floor mon |
RickS |
Feb 26 2007, 11:56 PM
Senior Member Group: Members Posts: 1,408 Joined: 17-April 06 From: 'False City', WA Member No.: 5,880 Region Association: None |
Sorry if this is a dupe-post, but I need some ideas badly. I added BigMark's excellent quad gauge, but the car did not have a temp sender of the wiring. The car is a '71 with a 2.0 4 cylinder.
Before I could add the new taco plate, I had to remove my old plate/cover. I was amazed that the bolts were just a little bit more than finger tight. I added a used taco plate/sender and it was hemoraging oil after I refilled the oil. The only, 'my bad' was reusing the old crush washers (yes, I will get some new ones tomorrow). Second, trying to apply an even amount of torque to the bolts is next to impossible. The rest of the case is dry, so I would like to keep it that way. Besides new crush washers, any suggestions on how to effectively seal it? Any goo to apply to the bolts, or? And how does one apply an equal amount of torque to the bolts - count each turn of the wrench? There must be a better way. HALP! Pic of DELEAKER.... Attached image(s) |
Aaron Cox |
Feb 27 2007, 12:09 AM
did it have the red oring on it?
Feb 27 2007, 01:50 AM
make sure the surface where the o-ring seats is clean. make sure the o-ring is clean. lube the o-ring with some fresh oil before assembly. make sure you got the paper gasket that goes between the plate and the cover. use new crush washers ...
don't overtighten, i forget what the correct torque is, but it's close to "hand-tight", 18 lbs or something like that. too much force and the plate warps ... (or worse) that usually does the trick. if not, use gobs of RTV and, for your own safety, make sure to stay away from Captn Krusty ... (IMG:style_emoticons/default/biggrin.gif) Andy |
McMark |
Feb 27 2007, 02:46 AM
Good god, not 18 ft/lbs. Try like 5 ft/lbs. (IMG:style_emoticons/default/ohmy.gif)
DNHunt |
Feb 27 2007, 07:55 AM
I like some Hylomar on the O ring and anaerobic Loctite on the bolts. Not much torque, Mark's about right.
lotus_65 |
Feb 27 2007, 08:19 AM
Senior Member Group: Members Posts: 1,608 Joined: 21-March 05 From: minneapolis, mn Member No.: 3,795 Region Association: Northstar Region |
if your case is warped a little, there's gonna be a gap, no matter what. there's a thread here somewhere that describes a fix to this part of the problem if the plate doesn't seat properly. i don't like putting sealant there because it'll goop into the engine case.
you also talk about "bolts" plurally, do you have one nut in the center, or several bolts or nuts around the edge? anyway~ after making sure you are seated properly, i'd clean the threads of oil really well, then reassemble. put a light coat of finger nail polish on the threads (first) and tighten the bolt(s) 1/8-1/4 turn past finger tight. add a bead of the polish (some bright color from your collection:)) around the nut or bolt(s). inspect it often. if something comes loose (it wont, the nail polish works great at locking threads), you'll see the polish has cracked and you'll know you need to redo it. paul |
RickS |
Feb 27 2007, 12:54 PM
Thanks for the replies. Here's the scoop:
Yup it had the "O" ring and it was in like-new condition. The case is not warped. The old plate cover sealed perfectly. The old plate and the taco mount with two small bolts equidistant from the center of the plate. Finger nail polish? My wife will wonder... but WTF, if it works.... Question time.............. I placed the crush washers on the bolts BETWEEN the sensor plate and the cover. Is that correct? It seemed like if I put them on the outside of the cover, they wouldn't help the seal any. But I am just logic-ing. Would it be smart to cut out a O shaped piece of gasket material and place that up against the O ring for added insurance? Can RTV, Hylomar, and the crush washers be found at any hack auto-parts store? what is RTV? Is it a thread-lock material like Locktite - which can be accomplished with nail polish on the threads or is it used on the bolt heads after installed. Also, how is hylomar used - coat the O-ring in it or just use fresh oil? I know different people have different approaches. Andy, forgive the stupid question, but what would the paper gasket between the sensor plate and cover accomplish, since the leak is between the sensor and the case? I didn't know a paper gasket was needed between the two. Would that help seal as well? Thanks for the word on the Capt'n! Sorry again for all the questions. Really appreciate the help before the oil drip bucket fills up. |
RickS |
Feb 27 2007, 12:57 PM
OH, and before I forgot - I was tempted to not reinstall the cover so I could more easily see where the leak was coming from. Good idea or bad?
SLITS |
Feb 27 2007, 01:18 PM
First, the crush washers go between the fastner head and the cover plate. The crush washer seals the fastner. The paper gasket seals between the sender plate and the cover plate at the fastners.
Second ..... RTV = Room Temperature Vulcanization Silicone Rubber .... comes in a tube .... known as gasket sealer, gasket maker, etc,..... Found at Home Depot (HI Trekkor), FLAPs, Harware Stores, Grocery Stores, etc The cover protects? the sender unit and has a clip to hook the sender wire to. Other than that, I cannot see it strengthening the assembly as it is to thin. It would be nice to have a flat plate guage (machinists' thingy) to check the plate for trueness, but .................... If the "O" ring was in good condition and the plate flat, it should have sealed if it kinda "snapped into place" without the fastners. The fasters just keep it from falling out under vibration (kinda). Now, I would add a small bead between the "O" ring and place where it seats on the plate. Install it and let the RTV set up before filling the engine (Sorry Cap'n). Don't over use the RTV, it just makes a mess and you don't want any on the interior of the engine. Hey, that's my bucks worth .... others' opinions may vary, but I don't care. (IMG:style_emoticons/default/biggrin.gif) |
RickS |
Feb 27 2007, 04:47 PM
Ron,
I am sure that if I was lost at the South pole a zillion miles from anyone or anything, you would find me and save my @$$. (IMG:style_emoticons/default/wink.gif) |
spunone |
Feb 27 2007, 04:54 PM
Senior Member Group: Members Posts: 945 Joined: 6-April 04 From: Anaheim CA Member No.: 1,901 Region Association: Southern California |
Did someone make a heavy duty Taco plate that won't bend like say a tostada Plate?? Just thinkin out loud (IMG:style_emoticons/default/happy11.gif)
Aaron Cox |
Feb 27 2007, 05:14 PM
Did someone make a heavy duty Taco plate that won't bend like say a tostada Plate?? Just thinkin out loud (IMG:style_emoticons/default/happy11.gif) IIRC - someone makes a billet one.... group buy anyone? LOL |
spunone |
Feb 27 2007, 06:14 PM
Did someone make a heavy duty Taco plate that won't bend like say a tostada Plate?? Just thinkin out loud (IMG:style_emoticons/default/happy11.gif) IIRC - someone makes a billet one.... group buy anyone? LOL Ok I searched and can not find please help OLD WISE ONE (IMG:style_emoticons/default/pray.gif) Billet taco plate??? |
Aaron Cox |
Feb 27 2007, 06:19 PM
i do not remember where i saw it...
maybe on STF? call clayton... he knows. |
SLITS |
Feb 27 2007, 06:23 PM
I thought it was you oh god of aluminum!
From 2004 on the Pelican Site milt Zeke member Registered: Jan 2002 Location: Ghetto by the Sea, Long Beach CA Posts: 12265 DD, you are right. And the threads are available for the VDO sender in SAE and M14 (which is also correct). You remember that I developed a billet sump plate that never got manufactured. So, I researched all of this. Mikey, tell our host exactly what you want, a VDO sender with the M14 threads that screws into the taco plate, or buy it anywhere. A Google of VDO will give you dozens of suppliers. The VDO website lists the PN. __________________ ' 88 Carrera, "Back in Black" (black on black) So there you go .... Milt had drawn up a taco plate and clutch pulley replacement but couldn't generate sufficient interest to get them manufactured. Any one with a lathe and a round of aluminum should be able to machine a replacement quite easily. |
spunone |
Feb 27 2007, 06:36 PM
Thanks Ron looks like he's a local Boy wonder if he's still makin them?ps I only work with 02 thin alum
904svo |
Feb 27 2007, 06:37 PM
904SVO Group: Members Posts: 1,118 Joined: 17-November 05 From: Woodstock,Georgia Member No.: 5,146 |
Did you install a new chrush washer between the oil temperture sending unit and
the taco plate. Unit will leak with out one. |
SLITS |
Feb 27 2007, 06:43 PM
Mueller |
Feb 27 2007, 07:01 PM
I have the billet plates all 3D rendered and ready to send the file to my CNC, just busy right now, I promised McMark that'll I'll have something in the next few weeks...with the 914 gone, I have been getting more progress done on my "other" projects which this is one of them...if someone beats me to the market, I'll have a some scrap material I guess for the recyclers (IMG:style_emoticons/default/smile.gif)
jd74914 |
Feb 27 2007, 07:10 PM
I have the billet plates all 3D rendered and ready to send the file to my CNC, just busy right now, I promised McMark that'll I'll have something in the next few weeks...with the 914 gone, I have been getting more progress done on my "other" projects which this is one of them...if someone beats me to the market, I'll have a some scrap material I guess for the recyclers (IMG:style_emoticons/default/smile.gif) How much are you planning on selling them for Mike? |
Lo-Fi Version | Time is now: 17th May 2024 - 04:42 PM |
