Flywheel specs needed, Need to know how to measure wear |
MiddleGACruiser |
Mar 6 2007, 05:15 PM
Hobbits? What Hobbits? Group: Members Posts: 115 Joined: 5-September 04 From: Porschenaire, GA Member No.: 2,694 Region Association: None |
How do I measure the wear on my flywheel and what are the specifications?
Mar 6 2007, 05:51 PM
The specs are in the haynes manual (I think)
you measure from the face that the pressure plate mounts to down to the face that the clutch disk rubs against. So you are measureing the depth of the flywheel from PP to clutch disk. If this is to much, you cannot grind it again. Rich |
MiddleGACruiser |
Mar 6 2007, 07:30 PM
Thanks for the info. I looked through the Haynes manual but could not find the specs. Anyone know what they are?
Lo-Fi Version | Time is now: 11th May 2024 - 08:31 AM |
