> Quick intake manifold/plenum question, can't find by example
Brando
post Mar 8 2007, 12:33 AM
BUY MY SPARE KIDNEY!!!
I'm trying to find out which is larger and flows better...
2.0 DJET intake manifold and plenum (diameter?)
or
1.8 LJET intake manifold and plenum (diameter?)
I gotta find some aluminum, copper or PVC tubing that is the proper diameter for either, and some rubber grommets to use as connectors. If I had a 2.0 intake manifold I could do comparison but I can't... If you can provide info please do help (IMG:style_emoticons/default/smile.gif)
Thanks!
banger
post Mar 8 2007, 04:47 AM
As far as the throttle bodies go, I believe they are all the same size on the backside. I will measure them tomorrow and post the dimensions.
Bleyseng
post Mar 8 2007, 08:41 AM
Aircooled Baby!
Djet 2.0l is 36mm
Ljet 1.8l is smaller IIRC and stepped to take the bigger intake to plenum gaskets?
According to Jake the best is
2.0L runners
2.0L bus plenum as the sidedraft TB flows better
Brando
post Mar 8 2007, 09:51 AM
Thanks guys! I'll wait for some more measurements to pop up. I might be stuck with the 1.8 intake and plenum until I locate a bus manifold.
- Lo-Fi Version Time is now: 7th December 2025 - 04:23 PM
