Back to the basics, Its the little things in life... |
grayson |
Nov 26 2003, 07:09 PM
Newbie Group: Members Posts: 27 Joined: 9-November 03 From: Emeryville, California Member No.: 1,325 |
I just repaired my door handel mechinism. My hands are covered in red grease, and black grease. Its a simple job, but it took me an hour or so.
Thats not the point though, I've been driving my new toy to work since my daily driver (saab) cant hold a charge and my mechanic is of course on holiday. Driving the 914 more and more I realize jeez, theres a lot I need to have fixed, or looked at... First of all, new oil and filter. What is a good recommendation? There is a bottle of 10W30 already from the seller, so I'm assuming I'll stick with that. What kind of filter? I cant get to the filter without a jack I assume, since I cant find it, and my Haynes book says its around the underside. What does it mean when shifting into 2nd gear too soon makes the engine rattle? Same thing can happen in 3rd sometimes. (I'm assuming this is because something on the engine is loose) What does it mean when 1st gear almost always grinds when starting from a stand still after warming up? The only way I can avoid this it seems, is to shift into 1st before the car rev's to an idle speed. (I'm assuming this is the synchromesh dieing) Turning on the heater to full heat makes the cabin smell like its on fire! Does this mean the heater box is causing some kind electrical fire? Fan works, and pushing all the sliders to about half way doesnt heat up or cause the smell. I think thats all I got for now. ANY help would be appreciated! OH and can anyone recommend a 914 mechanic in the East Bay San Francisco area? I'm just on the other side of the Caldicott tunnel. The engine is a 74 1.8 FI but the tranny is pre-73 linkage (its a hybrid really) Again, thanks for any help at all! |
ArtechnikA |
Nov 26 2003, 07:25 PM
QUOTE(grayson @ Nov 26 2003, 05:09 PM) First of all, new oil and filter. What is a good recommendation? There is a bottle of 10W30 already from the seller, so I'm assuming I'll stick with that. What kind of filter? I cant get to the filter without a jack I assume, since I cant find it, and my Haynes book says its around the underside. What does it mean when shifting into 2nd gear too soon makes the engine rattle? Same thing can happen in 3rd sometimes. What does it mean when 1st gear almost always grinds when starting from a stand still after warming up? The only way I can avoid this it seems, is to shift into 1st before the car rev's to an idle speed. Turning on the heater to full heat makes the cabin smell like its on fire! Does this mean the heater box is causing some kind electrical fire? Fan works, and pushing all the sliders to about half way doesnt heat up or cause the smell. oil: 10W-30's a little thin, especially for where you live, but not horrible especially if no extended high-speed runs or track time is involved. use quality oil, something not Castrol or Pennzoil. Valvoline is widely available. i use Mobil-1 15W-50 but you may not be up for a synthetic changeover until you get more familiar with your engine. filters - again - use quality, Mann, Knecht, Mahle, Purolator. NOT Fram. yes, it's underneath, kinda front-center. how do you shift into 2nd "too soon" ? anyway - it sounds like wonky engine and/or transmission mounts. pretty common on cars with a lot of years on 'em... 1st gear grinds are age wear, but it's made worse by improper clutch adjustment; check that first. it's documented in your Haynes, and the procedure is non-intuitive. it is, however, correct. probably the heat smell is your heat exhancgers have filled with oil leakage through the years - check your valve cover gaskets and pushrod tube seals. welcome to the joys of an aircooled car ... |
steve@ottosvenice.com |
Nov 26 2003, 07:29 PM
Member Group: Members Posts: 214 Joined: 9-November 03 Member No.: 1,324 |
Oil Fliter Mahle OC-61, Oil Wt 20-50 I use Valvo Mounts are probaley bad, Shift bushing are probaley worn also.Steve
McMark |
Nov 26 2003, 07:34 PM
If you want your engine to last a long time use Mobil 1 and Mann or Mahle filters. You can change the oil without a jack if the car hasn't been lowered. But you have to know where everything is. The oil filter is on the passengers side just behind the mount bar. If your filter wasn't put on by some meat-head gorilla mechanic you should be able to twist it off by hand (hard but do-able) otherwise get a spider filter wrench (the kind with three arms that open and close to accommodate different size filters.
Engine rattling (if I understand what you're describing) could be engine mounts or could be oil leaking from the rear main seal and causing the clutch to slip. If you can start from first okay, then it's not the rear main. The crunching going into first is probably a bad sychro. Start looking for another gear box. Check with EASY. You can take out the heater blower pretty easy and take it apart. It sounds like you're mechanically inclined enough to do it. Exhaust leaks can cause Carbon Monoxide to leak into the heater air stream and can be dangerous. Be careful. I know of a good 914 specialty shop in Novoto. (IMG:style_emoticons/default/wink.gif) |
grayson |
Nov 26 2003, 07:39 PM
Thanks guys!
redshift |
Nov 26 2003, 07:48 PM
What rpm do you shift out of 1st @?
M |
Brad Roberts |
Nov 26 2003, 08:26 PM
Stop. Dont drive it. The engine rattle you are hearing is detonation. You need to check the timing. Basically you said: "if I short shift to second" this loads the motor pretty good... which tells me it is detonationg under load.
You will burn a cylinder head up if the timing is not set correctly. B |
redshift |
Nov 26 2003, 08:41 PM
Listen to Brad.
I was worried. M |
grayson |
Nov 26 2003, 09:44 PM
Thanks Brad. I'll keep off the car until I drive it to a shop. Speaking of which, I'll probably be calling your shop soon!
Brad Roberts |
Nov 26 2003, 09:46 PM
That is fine.. in the mean time run some octane booster or 91 octane gas and see if it helps.
I have had 3 different cars get gas from 76 stations and have detonation problems. B |
grayson |
Nov 26 2003, 10:07 PM
Yes, its when I short shift. So if this is what you think it is, then its all the gas from 76? I made sure to use the highest octane stuff they had at the stations. =(
Will it have less of a damaging effect in cold weather? Also, does this look fixable? Or would it be easier to just put a new one on? The light still works, but insurance wants the lense to be replaced. http://vectorbug.com/914/LFquarter.jpg Again, thanks for the replies, I feel kind of lame that this is my first thread and I'm just mooching for advice. (IMG:style_emoticons/default/chairfall.gif) |
Brad Roberts |
Nov 26 2003, 10:42 PM
We/my body guy can fix it. His/our rates are acceptable and below the Bay area average of 75$ an hour for body work.
We also have the used turn signal pods for 20$ or so.... I think all 76 gas sucks right now... winter fuel. B |
Jake Raby |
Nov 26 2003, 11:07 PM
I agree with Brad.
First and foremost, find someone who KNOWS the Type IV engine, and don't spare a dime in going over the entire creature! Fix what needs to be fixed, before you scatter something! Its all about tuning! |
krk |
Nov 26 2003, 11:08 PM
Senior Member Group: Members Posts: 997 Joined: 27-December 02 From: San Jose Member No.: 22 |
grayson,
Don't fret to much about mooching advice here. We want 914's on the road. After a bit, you'll no doubt get a chance to contribute! kim. |
grayson |
Nov 26 2003, 11:55 PM
Great. Looks like octane boost and a half a tank of non-76 gas seemed to "do the trick". Never-the-less it looks like I'll be making my way to all914 in a couple weeks.
Now its time to watch the original Italian Job. |
rick 918-S |
Nov 27 2003, 12:09 AM
Hey nice rack! -Celette Group: Members Posts: 20,443 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region |
Do you own a copy of the movie? Or is it on TV? (IMG:style_emoticons/default/aktion035.gif)
Jake Raby |
Nov 27 2003, 12:10 AM
I just watched that a few days ago.....Better than the new one!
Yep, take the car to Brad and drop a few coins. I talk to alot of guys about engines, but Brad is by far one of the most knowledgeable of the TIV creature! Thats why HE is MY representative for the west coast! |
Brad Roberts |
Nov 27 2003, 12:16 AM
Wait until we have a NorCal 914 club day when we go out to several JunkYards and BUY all of their T4 engines (for your use). We will send out "scoping" parties the weekend before and make a plan of attack with a open car trailer and my crew cab... should be fun.
B |
Jake Raby |
Nov 27 2003, 02:08 AM
Damn, I have a buddy that sometimes comes back from Cali with an almost empty 53' trailer!
Lets plan that! (IMG:style_emoticons/default/boldblue.gif) |
Brad Roberts |
Nov 27 2003, 02:11 AM
We could actually cross breed with STF and have some of the VW guy's help us locate engines.. maybe give a small discount on future RAT engine purchases for those who participate. Just a thought.
B |
Lo-Fi Version | Time is now: 6th May 2024 - 07:30 PM |
