Faint Fuel Smell in Cabin? |
Heckler |
Mar 22 2007, 01:34 AM
Newbie Group: Members Posts: 46 Joined: 19-February 07 From: Los Angeles, CA. Member No.: 7,549 |
It dissipates once you get going, and it's noticable in the front trunk (which I kinda expected)...
Short of tearing into the fuel lines to see if they're tired and leaky, are there any likely suspects? P.O. had a handkerchief around/under the fuel cap, don't know if the gasket is leaky (is there anywhere to procure the gasket only or a '73 2.0)? Thanks! |
highways |
Mar 22 2007, 02:11 AM
Senior Member Group: Members Posts: 613 Joined: 18-June 05 From: Los Angeles, CA Member No.: 4,296 |
Umm, 914's always seem to have a faint smell of gas in the front. If you drop even a tiny drop of gas from the pump as you pull it out of the tank- you can smell it. I wouldn't worry a whole lot.
On the other hand... if you have never replaced all your fuel lines.. then you're dealing with 30 year old plastic lines and a disaster waiting to happen. Racer Chris makes awsome stainless steel lines to replace the plastic ones going through the center tunnel- definitely not a place you want a fire to start. So I used those and high pressure 5/16" fuel injection hose from Pep Boys (not the regular, non high pressure stuff) and things are looking good. I still have a leak from my pump and need to swap it out. Where is your pump located? Under the engine bay or in the front trunk? Pump is next thing to watch after replacing any antique fuel lines. (IMG:style_emoticons/default/beerchug.gif) |
Heckler |
Mar 22 2007, 02:18 AM
Umm, 914's always seem to have a faint smell of gas in the front. If you drop even a tiny drop of gas from the pump as you pull it out of the tank- you can smell it. I wouldn't worry a whole lot. On the other hand... if you have never replaced all your fuel lines.. then you're dealing with 30 year old plastic lines and a disaster waiting to happen. Racer Chris makes awsome stainless steel lines to replace the plastic ones going through the center tunnel- definitely not a place you want a fire to start. So I used those and high pressure 5/16" fuel injection hose from Pep Boys (not the regular, non high pressure stuff) and things are looking good. I still have a leak from my pump and need to swap it out. Where is your pump located? Under the engine bay or in the front trunk? Pump is next thing to watch after replacing any antique fuel lines. (IMG:style_emoticons/default/beerchug.gif) While I've had the car for a year, I'm just now getting around to driving it (and addressing it's issues), so I don't honestly know if the PO(s) replaced the fuel lines and/or had the fuel pump replaced/relocated... I guess I've got another thing to add to the list (though the car is in great shape given it's age, with only ~36K original miles, as hard as it is to believe)... Thanks! |
highways |
Mar 22 2007, 02:56 AM
Unfortunately, low mileage won't help when it comes to fuel lines. They still have probably had fuel sitting in them for 30+ years and they are 1970's plastic. The ones through the tunnel can be deceiving too because the ends that come out at each firewall are short steel sections. Mine were in decent shape and didn't appear to have any leaks- but I still replaced them just for piece of mind. You just never know when they are going to give out at this age. Also, everything after the fuel pump is high pressure- and pretty easy to replace so those ones in the engine bay are definitely worth redoing with the Pep Boys stuff if they look at all questionable. Here are the tunnel lines:
stainless steel fuel lines By the way, where are you in LA? |
Spoke |
Mar 22 2007, 04:30 AM
I've tracked down a couple of gas leaks in 914s inside the front trunk. So far, 2 of the smells came from gas caps. Had to replace those, one came from the little hose that goes from the overflow tank to the charcoal canister. In all cases, I used my nose to try to locate the source of the smell.
If it seems to be coming from the gas cap, keeping the fuel level lower than full can help reduce the odors until a new cap is purchased. The last one which I'm currently working on had fumes that seem to come from under the tank. As I took the gas tank out I realized that the PO relocated the fuel pump and filter to below the tank. The issue with this one was one of the clamps was not 100% tight. Since the tank is now out of the car, I'll be replacing all rubber fuel lines under the tank as well as the fuel filter. Unless the smell comes from spillage during refill, gas fumes are not a good thing and needs to be tracked down. |
bahnzai |
Mar 22 2007, 05:26 AM
Member Group: Members Posts: 307 Joined: 26-July 06 From: Columbia, SC Member No.: 6,509 Region Association: South East States |
You might want to drop the cover below the tank underneath the car (5 minute job). There is a 4-5" hole where the fuel lines come off the tank and into the car. Good place to check the lines and the bottom of your tank. I hope you don't have the problem I just fixed. I had the same symptoms, looked there and the bottom of the tank was slightly damp. Where the tank rests on a shelf above the peddle cluster, someone had put a piece of carpet. It got wet, held the moisture, and rusted the tank and the body. Gas had been barely weeping until I moved the tank, then it was a steady down pour. Anyway, hope that is not your issue, but I found it underneath the car. Tank was wet but the lines dry.
SLITS |
Mar 22 2007, 07:06 AM
If the fuel evaporative recovery system is not in place or the hoses are bad, you will get a fuel smell especially after filling up and when driving with a full tank as the fuel sloshes
yarin |
Mar 22 2007, 07:15 AM
'14-X'in FOOL Group: Members Posts: 988 Joined: 13-May 03 From: Guttenberg, NJ Member No.: 693 Region Association: North East States |
Check the rear firewall where the fuel lines exit below the engine tin, right in the middle. If you have the original plastic type fuel lines you will be able to see them. They might be coated or painted, but a surface scratch will reveal the type. I just replaced mine last year, they were definitely original.
I bought 3/8" and 5/16" brake line, a pipe bender and whatnot. If I had to do it again I would just go with Chris's set, much easier and cleaner. Good luck! |
BigD9146gt |
Mar 22 2007, 10:56 AM
OCD member Group: Members Posts: 376 Joined: 24-January 05 From: Sydney, Australia Member No.: 3,502 Region Association: Australia and New Zealand |
They are designed to do that. Its like that Old Spice commercial... it puts hair on your chest.
Tobra |
Mar 22 2007, 03:54 PM
Senior Member Group: Members Posts: 1,453 Joined: 22-August 05 From: Sacramento, CA Member No.: 4,634 |
same gas cap as an old bug, spend the 12 dollars
Heckler |
Mar 22 2007, 05:52 PM
I think I'll start with a new gas cap and a full inspection of the fuel lines/pump/filter... Since I've only owned it for the last year of it's ~34, I'm going to have to figure out the state of some of it's repairs, but other than the clear coat coming off and the paint paying for it, it's in remarkably good condition...
Thanks! |
orthobiz |
Mar 22 2007, 07:49 PM
Senior Member Group: Members Posts: 1,754 Joined: 8-January 07 From: Cadillac, Michigan Member No.: 7,438 Region Association: Upper MidWest |
I thought I read somewhere that the plastic lines in the tunnel usually don't go bad. Is replacing them for peace of mind or is there a known issue with tunnel failure?
Paul |
914rrr |
Mar 22 2007, 08:28 PM
Senior Member Group: Members Posts: 1,830 Joined: 1-July 03 From: Knoxville, TN Member No.: 874 Region Association: South East States |
I've also seen the gasket between the filler neck and the tank leak.
Does anybody sell just the replacement gasket? I thought the only way to get it was to buy the entire neck assmbly. I was lucky enough at the time to have a shop next to work where they could custom make gaskets. |
Lo-Fi Version | Time is now: 17th May 2024 - 03:57 PM |
