And the mystery continues |
ruddyboys |
Mar 31 2007, 09:57 AM
Hummel eigentümer Group: Members Posts: 594 Joined: 3-March 04 From: Monroe, NY Member No.: 1,749 Region Association: North East States |
Spring is here, so does the 914 problems. (IMG:style_emoticons/default/mad.gif)
To start the car has never really been on the road since I got it a few years ago, only short rides around the block. Before the winter I noticed the problem. The car starts right up, but the left side exhausts get very hot while the right side gets only warm (ran it only for a few minutes). If I put my hand and cover the top ports of the carbs the idle actually speeds up. I am getting fuel and spark. The engine is an early 70 1.7 with 96mm cylinders, dual dells. I tried adjusting the valves and no change, I am thing to getting a compression gauge and seeing if maybe I have a compression leak somewhere, any other things it could be? |
Katmanken |
Mar 31 2007, 10:11 AM
Hot means lean. Better adjust or repair the carbs on the hot side before you start having serious problems.
Ken |
dr914@autoatlanta.com |
Mar 31 2007, 10:13 AM
914 Guru Group: Members Posts: 7,857 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
Spring is here, so does the 914 problems. (IMG:style_emoticons/default/mad.gif) To start the car has never really been on the road since I got it a few years ago, only short rides around the block. Before the winter I noticed the problem. The car starts right up, but the left side exhausts get very hot while the right side gets only warm (ran it only for a few minutes). If I put my hand and cover the top ports of the carbs the idle actually speeds up. I am getting fuel and spark. The engine is an early 70 1.7 with 96mm cylinders, dual dells. I tried adjusting the valves and no change, I am thing to getting a compression gauge and seeing if maybe I have a compression leak somewhere, any other things it could be? sounds like a vacuum leak. |
ruddyboys |
Mar 31 2007, 10:25 AM
Where would I start checking for vacuum leal
SLITS |
Mar 31 2007, 12:09 PM
JPB |
Mar 31 2007, 02:26 PM
Easy there greezy, its probably as symple as synchronizing the carbs. That sounds more like a synchro problem than anything and yes your car will seem to run fine while they are off. Start there and come back if it ain't that. (IMG:style_emoticons/default/beer.gif)
Lo-Fi Version | Time is now: 15th May 2024 - 12:50 PM |
