Early vs Late Rear -4 Calipers, Will early work on a 1974? |
kconway |
Apr 9 2007, 08:07 PM
Senior Member Group: Members Posts: 1,347 Joined: 6-December 04 From: Monrovia, CA Member No.: 3,231 Region Association: Southern California |
I understand the innerds of the early and late calipers are different, but are they calipers as a whole interchangeable on my 74? If so, is one more desirable?
Eric_Shea |
Apr 9 2007, 08:08 PM
Bolt right on
Joe Ricard |
Apr 9 2007, 09:22 PM
I thought you had to use early caliper with early rotor.
Something with the off set being 1/8 inch different |
Eric_Shea |
Apr 9 2007, 10:35 PM
That's fronts... and it's more than 1/8" (IMG:style_emoticons/default/wink.gif)
So.Cal.914 |
Apr 10 2007, 01:22 AM
Works , did it. (IMG:style_emoticons/default/smile.gif)
If real early it may not look exactly the same. |
Joe Ricard |
Apr 10 2007, 05:58 AM
Ah, I didn't read the title all the way.
Yup bolt right up. |
Lo-Fi Version | Time is now: 20th May 2024 - 04:27 PM |
