cylinder head rings dont FIT!!!!, am I doing something wrong????? |
DrifterJay |
Dec 2 2003, 06:21 PM
I break stuff... Group: Members Posts: 1,034 Joined: 25-May 03 From: Oceanside, California Member No.: 737 Region Association: None |
what gives...I ordered the 1.7 gasket kit from pelican, received it last night, and it is supposedly the 1.7 as stated on the package. So I am putting the gaskets in the head and the rings do not fucking FIT!!!!!there are two different sizes, one which is about 1.5 too big in diameter, but I believe is the the correct thickness, the other which is much smaller and thicker. Question is, they should just slid right in and be snug right? Or do they have to be forced? (IMG:style_emoticons/default/ohmy.gif) or did they give me 1.8 or 2.0 gaskets?
Jared |
Aaron Cox |
Dec 2 2003, 06:24 PM
ouch...... (IMG:style_emoticons/default/headbang.gif)
URY914 |
Dec 2 2003, 06:27 PM
I built the lightest 914 in the history of mankind. Group: Members Posts: 120,693 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None |
BFH (IMG:style_emoticons/default/smash.gif)
DrifterJay |
Dec 2 2003, 06:33 PM
bfh? boo fucking hoo???
Aaron Cox |
Dec 2 2003, 06:34 PM
nope
BFH = Big F-ing hammer- i think he was kidding tho (IMG:style_emoticons/default/rolleyes.gif) |
seanery |
big fucking hammer
DrifterJay |
Dec 2 2003, 06:35 PM
so do I have to press them in or are they the wrong ones???
DrifterJay |
Dec 2 2003, 06:36 PM
seanery |
sound wrong to me
DrifterJay |
Dec 2 2003, 06:40 PM
FRUCK MOTHER FRUCK...freaking pelican...on the package it clearly states be sure these are the correct gaskets before opening because they will not be returned once opened....JOY (IMG:style_emoticons/default/clap56.gif)
Aaron Cox |
Dec 2 2003, 06:41 PM
post a pic....maybe someone can help (IMG:style_emoticons/default/chair.gif)
DrifterJay |
no camera...cant find it...gonna make those fuckers fit...I am pissed
seanery |
Dec 2 2003, 06:48 PM
if they aren't right, don't do it.
wrong is wrong, can't be made right. |
redshift |
Dec 2 2003, 07:06 PM
Hey, wait, call Pelican.
M |
McMark |
Dec 2 2003, 07:14 PM
Are the small thick ones for between the cylinders and the case? You don't have to run a seal between the head and the cylinder. In fact it's often recommended to be left out. Compression bump!
URY914 |
Dec 2 2003, 07:17 PM
See if those are between the case to cylinder, not the cylinder to head.
Sorry about the BFH reply. Seemed to fit the post at the time. Paul |
Bleyseng |
Do not use a a headgasket as they leak. Lap the cylinders into the head with valve lapping compound.
Geoff |
DrifterJay |
Dec 2 2003, 07:22 PM
you mean like a silicon gasket sealant of some kind?
Aaron Cox |
Dec 2 2003, 07:24 PM
its an abbrasive compund. "valve lapping compund".
(IMG:style_emoticons/default/wink.gif) |
redshift |
Dec 2 2003, 07:26 PM
Lapping is the tight mating of surfaces, by leveling those surfaces with friction created between (the parts).
I'm out of my place, but it's like a heavy cut compound, sounds like. M |
Lo-Fi Version | Time is now: 19th May 2024 - 02:52 AM |
