Push rod tube seal replacement |
whitey |
Apr 20 2007, 11:58 AM
Member Group: Members Posts: 146 Joined: 8-February 07 From: Coto de Caza Member No.: 7,508 |
I want to replace my push rod tube seals without removing the heads. Do I twist and pull the tubes with pliers? Also, my engine is out of the car and I'm reinstalling the injection, re-sealing and doing a engine clean up...My compression was good at 130 psi with no smoking. I don't really want to pull the heads and cylinders but do you see any real advantage to doing this, (ie. honing the cylinders and removing carbon).
Thanks for your response |
Lo-Fi Version | Time is now: 17th May 2024 - 11:02 PM |
