BIG L-Jet problems, Comments welcome |
srthompson01 |
Apr 23 2007, 11:16 PM
Newbie Group: Members Posts: 45 Joined: 24-September 06 From: oklahoma Member No.: 6,906 |
My fuel injection problem is complicated.
Bought the car ( 75 1.8L L-jet) not running. PO said air-flow sensor needed replacement and probably more. Tried to start car and it refused to fire. New plugs, wires, points. I inspected the car top to bottom and found the oil reeked of gas, so I changed the oil. I obtained all the manuals and tech articles I could find and checked the following systems. And then some. Airflow sensor - Textbook perfect according to manual ( infinite resistance @ closed, 0 @ slight open etc ) Fuel Pressure - 35psi ( manual recommends 35psi) Temp sensor - 3Kohms @ 56 degrees ( pretty close relative to Bosch manual) No noticeable air leaks. Every 10 or so attempts to start the oil became fuel contaminated and required changing. While disassembling the system I was able to get the engine to start with the cold start valve removed, functionally bypassing the airflow meter and running VERY rich and no throttle control. While checking the injectors, they all functioned but were putting out HUGE squirts of fuel while the airflow meter was being bypassed and should not have been putting out ANY fuel. I was unable to find any troubleshooting guide that fit my circumstances. I have been over and over it in my head and I want to point my finger at a faulty ECU, however, all I hear is â Its never the ECU. Check this first .â I put a carb on my beloved 914 and she runs well, but I want the fuel injection. Any ideas???? |
Apr 23 2007, 11:22 PM
Custom Member Group: Members Posts: 24,584 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
http://www.914world.com/specs/links.php
There is a link there for L-jet This is the best L-jet site I have found for diagnostics. You may start looking at the realy pack that is under the battery, it is what provides power to the injectors...if it is stuck in the wrong position, the injectors may stay running even though the AFM is not sending that signal. It seems to be a common issue, the realy pack. Rich |
Rockaria |
Apr 24 2007, 11:08 AM
ZippidyDoDah... Group: Members Posts: 817 Joined: 2-May 03 From: Southwest, USA Member No.: 645 Region Association: None |
My Old L-Jet system came with two injectors stuck open. My local FLAPS had some rebuilt ones for not too much. They went in real easy and fixed the rich problem. I also took the Cold Start valve out of the system.
(IMG:style_emoticons/default/smile.gif) http://www.914world.com/specs/links.php There is a link there for L-jet This is the best L-jet site I have found for diagnostics. You may start looking at the realy pack that is under the battery, it is what provides power to the injectors...if it is stuck in the wrong position, the injectors may stay running even though the AFM is not sending that signal. It seems to be a common issue, the realy pack. Rich |
dr914@autoatlanta.com |
Apr 24 2007, 02:52 PM
914 Guru Group: Members Posts: 7,873 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
check the air flow meter for a sticking flap and then check to see if the first three wires coming from the control unit (they are in a bundle together) are not grounded. (some 1.8s have an altitude compensator wiring loom coming from the control unit, and some owners ground these wires causing very rich running.
srthompson01 |
Apr 24 2007, 07:11 PM
I tried to be as thorough as possible. I want to try the FI again, but the carb does work better than I expected from what my fellow club members report about them.
jim_hoyland |
Apr 24 2007, 09:34 PM
Get that VIN ? Group: Members Posts: 9,311 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
As a long time 1.8 L-jet'r, I agree with all of the above. Don't underestimate the potential for air leaks on hoses and fitting that look ok.
I've installed a vacumn gauge to the plenum to monitor any loss of pressure--leaks. |
alpha434 |
Apr 24 2007, 09:48 PM
My member number is no coincidence. Group: Members Posts: 3,154 Joined: 16-December 05 From: Denver, CO Member No.: 5,280 Region Association: Rocky Mountains |
Hehehe....
Broken rings. Compression test. |
srthompson01 |
Apr 24 2007, 11:20 PM
compression is good, car cruises easily at 100mph. and still gets 30 mpg.
I just figure if I am going to pull the carb and spend at least a day trying to get the FI to work I need the experts opinions before I put it under the wrench. Nothing is going to tick me off more than all that time, effort and $$$ to put the FI back together and have it still not work, when the carb did. Adding to the frustration, I live in a very rural area and if I need any parts I have to order them, usually online, usually about a week. |
ClayPerrine |
Apr 25 2007, 02:07 PM
Life's been good to me so far..... Group: Admin Posts: 15,485 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
Plan a road trip to Ft. Worth one day this summer. Load the parts up in the car, and I will help you get it working again.
srthompson01 |
Apr 27 2007, 01:20 PM
Thanks Clay I'll do that this summer.
I don't feel so bad since so few others had any ideas. I'm ready to lose the carb, but not not at the cost of losing my best toy. Stephen |
TheCabinetmaker |
Apr 27 2007, 04:21 PM
I drive my car everyday Group: Members Posts: 8,301 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
Road trip? Did I hear road trip? (IMG:style_emoticons/default/driving.gif)
Hey, this is my 3000th post!!!!!!!!!!!! |
ClayPerrine |
Apr 28 2007, 08:23 AM
Road trip? Did I hear road trip? (IMG:style_emoticons/default/driving.gif) Hey, this is my 3000th post!!!!!!!!!!!! Hey Woody! Can you build this and bring it with you?? Make it in some wood that I can stain with a nice cherry stain to match the rest of my house. Yea, I know the drawing is a crappy scanned copy. It is the only one we have. And Yes, it is in Spanish. The hispanic "carpenter" that the builder had tried to build this 4 times, and failed miserably, even after I paid to have the blueprint translated to spanish. Seems he couldn't read a blueprint. This is the only copy we were able to get back, and we salvaged that from the trash. Oh.. and how much to build it??? (IMG:style_emoticons/default/hijacked.gif) |
TheCabinetmaker |
Apr 28 2007, 06:35 PM
Road trip? Did I hear road trip? (IMG:style_emoticons/default/driving.gif) Hey, this is my 3000th post!!!!!!!!!!!! Hey Woody! Can you build this and bring it with you?? Make it in some wood that I can stain with a nice cherry stain to match the rest of my house. Yea, I know the drawing is a crappy scanned copy. It is the only one we have. And Yes, it is in Spanish. The hispanic "carpenter" that the builder had tried to build this 4 times, and failed miserably, even after I paid to have the blueprint translated to spanish. Seems he couldn't read a blueprint. This is the only copy we were able to get back, and we salvaged that from the trash. Oh.. and how much to build it??? (IMG:style_emoticons/default/hijacked.gif) Can I build it? But of course. Can i bring it with me? not in a 914!!!!!!!!!!!!! I'll work on a new drawing and get it to ya. Then you can take a red pencil and draw all over it, and send it back to me. |
Lo-Fi Version | Time is now: 27th May 2024 - 08:58 PM |
