Tip off for auction item at WCR, Megasquirt in a stock FI package |
DNHunt |
May 26 2007, 04:25 PM
Finished, it's all in the box.
Dave |
DNHunt |
May 26 2007, 04:34 PM
Here's the guts. TechEdge 2BO Wideband O2 driver is on top; MS II on a version 3 ECU on the bottom. Connections are on the left; power and grounds on the right.
Dave |
May 26 2007, 05:03 PM
Resident German Group: Admin Posts: 41,662 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
DNHunt |
May 27 2007, 05:59 PM
Here's all the gear. ECU, distributor, MPS, Throttle body and TPS
Bleyseng |
May 28 2007, 10:23 AM
Aircooled Baby! Group: Members Posts: 13,035 Joined: 27-December 02 From: Seattle, Washington (for now) Member No.: 24 Region Association: Pacific Northwest |
Pretty cool Dave! (IMG:style_emoticons/default/drunk.gif)
Thats what I want to do next, but my car is running soo well I don't have the heart to switch it over. (IMG:style_emoticons/default/w00t.gif) |
LS6/914 |
May 28 2007, 10:31 PM
Never leaves the shop member Group: Members Posts: 301 Joined: 1-October 03 From: Port Townsend,WA Rivabelosa/Madrid ESP Member No.: 1,215 Region Association: Pacific Northwest |
Dave, Can you monitor the wideband O2 real time with a timing curve, MAP, TPS, individual EGT, with the MS? Larry
sixnotfour |
May 28 2007, 10:36 PM
914 Wizard Group: Members Posts: 10,433 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
Nice job Dave
How much do you think that set up will bring at auction ? ballpark ? |
DNHunt |
May 29 2007, 08:28 AM
Larry
Yes you can, but it is kind of a pain. The tuning software's desktop has 8 gauges that can be assigned. They also give a numerical value. The hard part is getting the right gauges up. They have to be assigned in a .ini file. You can also datalog those functions. Jeff I don't have any idea. It is certainly apparent from the amount of time and the cost of the parts that it wouldn't fly as a second business. The only way I'd consider doing it again is if a beautiful woman in a tight wet T shirt asked with a smile on her face. It is kind of limited to 2.0 l engines because of the harness. Dave |
DNHunt |
Jun 7 2007, 09:51 AM
Well I finally got it started. It's not running well but, I haven't started timing and tuning yet.
What a struggle. I have tried to follow the stock harness and I got tripped up by a little detail I missed. I ran my switched 12 volt power off the 4 pin connector that ran the stock ECU. Pins I, II and IV all have switched 12 V so, I powered the MS and WBO2 off of I and the power for the injectors off of II and IV. That's a big problem cause II and IV are only hot with the key to start. The thing would cough and die, DOH!!. Looking at it now I can see a fine line indicating a trace on the relay board. It's all in the details. I still hope to have it down there for WCR but, if I run into anymore snaffus of my own creation I probably won't. Back's to the wall. Dave |
rhodyguy |
Jun 7 2007, 10:26 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,082 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
cool beans dave. a tinkerers delight.
k |
effutuo101 |
Jun 7 2007, 10:50 AM
Advanced Member Group: Members Posts: 2,734 Joined: 10-April 05 From: Lemon Grove Member No.: 3,914 Region Association: Southern California |
Nice job Dave! your attention to detail and desire to keep a "stock" look is amazing. Keep up the great work. See you soon.
agrump |
Jun 7 2007, 11:29 AM
Member Group: Members Posts: 141 Joined: 13-November 04 From: Atlanta, GA Member No.: 3,103 |
ConeDodger |
Jun 7 2007, 11:30 AM
Apex killer! Group: Members Posts: 23,602 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California |
The only way I'd consider doing it again is if a beautiful woman in a tight wet T shirt asked with a smile on her face. Dave Shoot Dave, I can arrange that very easily. (IMG:style_emoticons/default/biggrin.gif) |
sean_v8_914 |
Jun 7 2007, 02:18 PM
that is a sweet install. will a stock 2.0 yeild higher HP with the MS? what is the gain over stock D-Jet
Jun 7 2007, 09:15 PM
914 Idiot Group: Members Posts: 14,991 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
I think the main benefit is having new parts. Ones you can actually find replacements for, unlike (say) the stock MPS.
Plus the ability to tune the system very easily. --DD |
DNHunt |
Jun 9 2007, 08:15 PM
(IMG:style_emoticons/default/biggrin.gif) Well it's almost done. I actually went on a little drive with the package in the car and it ran well. My hope is that whoever wins this will just need to weld an O2 bung in the exhaust, install the stuff and drive away. We'll see. It should be pretty close.
Luckily, I had an old file with the tuning I did on a dyno with this engine so, it didn't take much to get it running well. The acceleration stuff is different with MS II so I had to work over that. And, this thing is a cold blooded pig to start. I needed a ton of cranking fuel. I have a few concerns about flooding cause it seemed like so much gas. Dave |
DNHunt |
Jun 13 2007, 07:03 AM
All done. The last of the docs are printed and the files are on a USB stick. I'm just getting ready to head out in the garage and take it out of the car. I had a nice drive last night and worked out the last few bugs. It should be good to go. Olld Smokie is gonna miss this system. It looked like it did when I got it before I started mixing and matching parts.
Here's the docs Dave Attached image(s) |
rhodyguy |
Jun 13 2007, 01:00 PM
take one of my 009s, the webers off the type 1, and keep motorvating. i've got some intakes for you to use also. carefull...once carbed, you might even like it.(IMG:style_emoticons/default/wink.gif)
k |
DNHunt |
Jun 13 2007, 03:27 PM
Well it's on the way. I'm gonna go take a nap
Lo-Fi Version | Time is now: 29th May 2024 - 02:56 AM |
