Fuel lines and vacuum hoses, diagram or documented pics? |
DanT |
May 7 2007, 06:46 PM
OK, I am to the point on my rebuild to run the fuel lines and Vac hoses...
I need a diagram or pic of where the various lines and hose go to...please. thanks (IMG:style_emoticons/default/smile.gif) Attached image(s) |
skline |
May 7 2007, 07:37 PM
I used to have one somewhere, I will look for it and see if I can find it. (IMG:style_emoticons/default/confused24.gif)
mrhurtalot |
May 7 2007, 08:16 PM
VRRRRRRROOOOOOOOOM! Group: Members Posts: 323 Joined: 5-October 06 From: Yukon, Oklahoma Member No.: 6,996 |
ill dig mine out from AA 2.0 correct?
Allan |
May 7 2007, 08:26 PM
I think that you will find that not all 2.0 diagrams are the same. If you use the pelican diagram, remember that there are a couple connections that are wrong.
There is also the factor of head vents. From what I have seen, most diagrams don't take them into consideration. I actually found the best of all evils is to use the pelican article and improvise... |
john rogers |
May 7 2007, 08:36 PM
Senior Member Group: Members Posts: 1,525 Joined: 4-March 03 From: Chula Vista CA Member No.: 391 |
They used to be on the Pelican site?
srthompson01 |
May 7 2007, 09:01 PM
Newbie Group: Members Posts: 45 Joined: 24-September 06 From: oklahoma Member No.: 6,906 |
Is this close enough?
May 7 2007, 09:20 PM
914 Idiot Group: Members Posts: 14,984 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
That's one of the ones from Pelican. Does that have the correct Decel Valve hoses, or does it have the large hoses reversed?
The diagram on Pelican is largely correct; the only real problem I know of is that the two large hoses to the Decel Valve are swapped. Charlie Davis also has diagrams on his Rennlist site somewhere: http://members.rennlist.com/chuxter Bleyseng has a factory picture that he has labeled (including showing which hoses on the picture are wrong), but it is just the bare engine and doesn't show anything of the engine bay. --DD |
mrhurtalot |
May 7 2007, 10:59 PM
i like that painting the inside. howd you do it? PM me details if you dont mind.
mrhurtalot |
May 7 2007, 11:01 PM
oh.. just dug this up. cant remember where i got it.
Attached thumbnail(s) |
DanT |
May 7 2007, 11:04 PM
i like that painting the inside. howd you do it? PM me details if you dont mind. I don't quite follow your question (IMG:style_emoticons/default/confused24.gif) thanks for the diagrams everyone. |
mrhurtalot |
May 7 2007, 11:25 PM
i meant like the orange.
or am i being stupid and it came that way? |
DanT |
May 7 2007, 11:47 PM
when I took the motor apart for the rebuild I bead blasted and painted all the engine tin in Phoenix Red, to match the car.
Attached thumbnail(s) Attached image(s) |
Bleyseng |
May 8 2007, 08:51 AM
Factory pic
andys |
May 8 2007, 10:59 AM
DanT |
May 8 2007, 07:13 PM
oh.. just dug this up. cant remember where i got it. I have a question on that diagram regarding hose # 2. I was under the impression that it ran from the charcoal cannister to the air cleaner, anyone? Andys I believe that is what that diagram shows. #2 going from charcoal canister (evap canister/filter) to the front inlet on the air cleaner. (IMG:style_emoticons/default/smile.gif) on the drawing the air filter is depicted by a dashed line (outline) |
ConeDodger |
May 8 2007, 09:14 PM
Apex killer! Group: Members Posts: 23,581 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California |
oh.. just dug this up. cant remember where i got it. I have a question on that diagram regarding hose # 2. I was under the impression that it ran from the charcoal cannister to the air cleaner, anyone? Andys I believe that is what that diagram shows. #2 going from charcoal canister (evap canister/filter) to the front inlet on the air cleaner. (IMG:style_emoticons/default/smile.gif) on the drawing the air filter is depicted by a dashed line (outline) Dan, Sorry for the hijack but did you find an apartment for your daughter? One of SVR's members has a daughter who is the leasing manager of a nice complex in Roseville... |
DanT |
May 8 2007, 10:09 PM
oh.. just dug this up. cant remember where i got it. I have a question on that diagram regarding hose # 2. I was under the impression that it ran from the charcoal cannister to the air cleaner, anyone? Andys I believe that is what that diagram shows. #2 going from charcoal canister (evap canister/filter) to the front inlet on the air cleaner. (IMG:style_emoticons/default/smile.gif) on the drawing the air filter is depicted by a dashed line (outline) Dan, Sorry for the hijack but did you find an apartment for your daughter? One of SVR's members has a daughter who is the leasing manager of a nice complex in Roseville... Rob, thanks for asking...she found a very nice apartment with an attached garage very near the Galleria. I like the fact that she can come home late, hit the button, get inside, close the garage door with remote and then go up her enclosed private stairway right into her apartment....these units were supposed to be condos, but did not sell so they converted to apartment....very cool for her first place completely on her own with no room mate. (IMG:style_emoticons/default/smile.gif) |
ConeDodger |
May 9 2007, 10:54 AM
oh.. just dug this up. cant remember where i got it. I have a question on that diagram regarding hose # 2. I was under the impression that it ran from the charcoal cannister to the air cleaner, anyone? Andys I believe that is what that diagram shows. #2 going from charcoal canister (evap canister/filter) to the front inlet on the air cleaner. (IMG:style_emoticons/default/smile.gif) on the drawing the air filter is depicted by a dashed line (outline) Dan, Sorry for the hijack but did you find an apartment for your daughter? One of SVR's members has a daughter who is the leasing manager of a nice complex in Roseville... Rob, thanks for asking...she found a very nice apartment with an attached garage very near the Galleria. I like the fact that she can come home late, hit the button, get inside, close the garage door with remote and then go up her enclosed private stairway right into her apartment....these units were supposed to be condos, but did not sell so they converted to apartment....very cool for her first place completely on her own with no room mate. (IMG:style_emoticons/default/smile.gif) Dan, Glad to hear that. If the apartment is on the North side of the Galleria bordering the undeveloped land next to Galleria I have a very good friend who is a Placer County Sherrifs Deputy living in a condo there. Let me know if you need help with anything. By the way, that is a very safe neighborhood. If she starts feeling the need to visit Thunder Valley Casino just to her North have her flush a $100.00 down the toilet and the feeling will usually pass. |
andys |
May 9 2007, 11:30 AM
oh.. just dug this up. cant remember where i got it. I have a question on that diagram regarding hose # 2. I was under the impression that it ran from the charcoal cannister to the air cleaner, anyone? Andys I believe that is what that diagram shows. #2 going from charcoal canister (evap canister/filter) to the front inlet on the air cleaner. (IMG:style_emoticons/default/smile.gif) on the drawing the air filter is depicted by a dashed line (outline) Ah ha, a closer look reveals the dashed line air cleaner. Thanks! Andys |
Lo-Fi Version | Time is now: 11th May 2024 - 06:50 PM |
