akellym |
Eyes Of The Deep Battle ![]() ![]() ![]() Group: Members Posts: 598 Joined: 25-July 04 From: Annandale, MN Member No.: 2,395 Region Association: Northstar Region ![]() |
Here's my example, fuel Y block right in the middle on the fire wall (IMG:style_emoticons/default/biggrin.gif)
Attached image(s) ![]() |
lotus_65 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,609 Joined: 21-March 05 From: minneapolis, mn Member No.: 3,795 Region Association: Northstar Region ![]() |
Mine are really close to the same length. I have a trick brass splitter that's positioned just off-center.
I noticed the 1&2 carb do get a little more pressure at low regulator load (between .5lbs-a bit over 1lb, but that's not where I run it), it's the longer line by maybe 2", not the shorter. I don't think the architecture of the splitter would fail to distribute fuel pretty equally. That part was made by a pro race mechanic, Chappy your guy Bob Johnson. Paul |
lotus_65 |
Kelly, mine's not as attractive but functionally identical. I still have the return line from the FI setup. The return is internally restricted to bleed off up to 2lbs excess fuel pressure, but *might* on a good day return .5lbs. It's really restricted...
Anyway, that car has a lot of acrylic on it. I especially notice the rain tray... Vcool. I've thought about trying to get some plexi molded similar to stock, but tight to the lid like that one. pfb |
Lo-Fi Version | Time is now: 12th July 2025 - 04:54 PM |
