OK- Here Comes A Dumb Question, Just Never Done This Before |
kconway |
May 8 2007, 12:35 PM
Senior Member Group: Members Posts: 1,347 Joined: 6-December 04 From: Monrovia, CA Member No.: 3,231 Region Association: Southern California |
I'm prepping my car for bodywork and paint. I'm going to pull the engine and trans then have it flatbed towed to my bodyshop. (IMG:style_emoticons/default/welder.gif)
Here's the question. Without the engine/trans in, what keeps the rear hubs from falling out? (IMG:style_emoticons/default/confused24.gif) Is it the outer CV joint? I guess didn't plan on taking the axels off completely. Am I okay to have it moved around that way without damaging something? Kev |
Cap'n Krusty |
May 8 2007, 12:40 PM
Remove the axles with the stubs, remove the stubs from the axles, reinstall the stubs and tighten the castellated nuts. They don't have to be brought to full torque, but they need to be tight. The Cap'n
G e o r g e |
Dr Group: Members Posts: 1,905 Joined: 20-September 05 From: Southern Cal Member No.: 4,832 Region Association: None |
you will be fine, just bag the ends up
worst case take a bungie cord and sling your axels so that they are level edit or listen to the Captain |
So.Cal.914 |
May 8 2007, 01:15 PM
You don't need to pull the stub axle's to remove the outer CV's but all you
need to do is use some wire and make a loop and hang your axle's from above. Make sure the loop is loose so the axle can spin inside it, bailing wire is good, insulated wire can catch and wrap around axle. |
Gint |
May 8 2007, 03:34 PM
Mike Ginter Group: Admin Posts: 16,071 Joined: 26-December 02 From: Denver CO. Member No.: 20 Region Association: Rocky Mountains |
I sacrifice a couple of coat hangers and make nice big loops for the axle shafts so they hang about level or a little high at the inner (loose) ends. Hasn't failed me yet.
Lo-Fi Version | Time is now: 13th May 2024 - 01:51 PM |
