Momo Adapter for Early, does the column bushing come off? |
tyler |
May 10 2007, 08:40 AM
Member Group: Members Posts: 335 Joined: 24-September 03 From: southern california Member No.: 1,192 |
I'm about to return another momo adapter hub that's supposed to fit an early (1970) since it won't go down far enough on the shaft to engage the directional canceling. It's a shoulder on the steering shaft that keeps it from going down far enough. I noticed in the parts diagram that this isn't a "shoulder" but a "bushing". If there's splines under this bushing, I think the adapter would fit.
Before I pull the wheel yet another time, can someone tell me if that there's spline under that bushing? |
Lightweight_911 |
May 12 2007, 05:49 AM
Member Group: Members Posts: 71 Joined: 7-October 06 From: London, UK Member No.: 7,008 |
When replacing a std wheel with a Momo wheel & hub you don't need to remove anything apart from the original wheel (& transfer the turnsignal cancelling ring over to the new hub).
Lo-Fi Version | Time is now: 23rd May 2024 - 11:50 AM |
