Porsche side stripe..., For Bumblee Bee |
Aircooledfool |
May 19 2007, 03:18 PM
Member Group: Members Posts: 106 Joined: 17-September 06 From: Texas Member No.: 6,858 Region Association: None |
Does anyone know of a source for the "correct" PORSCHE side stripe for a Bumblee Bee? Also, when these are installed during a repaint, are they usually put on during the base coat appliactions and then cleared over?
Thanks- |
Porsche Rescue |
May 19 2007, 08:04 PM
Jeff Bowlsby, resident authority on everything LE, can help you. Email him direct at bowlsby@sbcglobal.net
Also, check out his LE website here http://members.rennlist.com/914_canam/ if you haven't already. I'm not an authority, but since the factory did not clear coat, I think they were originally applied over the factory black. I would not clear coat them so as to allow removal/replacement if needed without disturbing any paint. |
scotty b |
May 20 2007, 05:30 PM
Original paint was a single stage and no I would not recommend clearing over the stripe. Finish out the paint job (including wet sand amd buff) then apply the decal.
dr914@autoatlanta.com |
May 31 2007, 06:22 PM
914 Guru Group: Members Posts: 7,833 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
sunflower yellow stripe sets are commonly available in the aftermarket.
Lo-Fi Version | Time is now: 5th May 2024 - 11:50 PM |
