| BarberDave |
May 30 2007, 05:46 AM
Barberdave ![]() ![]() ![]() Group: Members Posts: 1,605 Joined: 12-January 03 From: Wauseon Ohio Member No.: 135 Region Association: Upper MidWest |
Hi ,I have a new Alternator Wireing Harness for a 914 type 4. Ques. Will this also fit a 912E, they have a type 4 ,right? I figured it would be the same! Dave (IMG:style_emoticons/default/slap.gif) |
| Joe Ricard |
May 30 2007, 06:37 AM
CUMONIWANNARACEU ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,811 Joined: 5-January 03 From: Gautier, MS Member No.: 92 |
Shouldn't really matter as long as the connector fits the voltage regulator. Even then you can change that. take the cover off the back of the altenator and make it how you need it with new wire.
| JeffBowlsby |
May 30 2007, 08:26 AM
914 Wiring Harnesses & Beekeeper ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,184 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None
The Alt harness connects the alternator, relay board and starter. If the 912E relay board is in the same position relative to the engine as the 914, it should work.
(IMG:style_emoticons/default/smilie_pokal.gif) Hi ,I have a new Alternator Wireing Harness for a 914 type 4. Ques. Will this also fit a 912E, they have a type 4 ,right? I figured it would be the same! Dave (IMG:style_emoticons/default/slap.gif) |
Lo-Fi Version | Time is now: 14th February 2026 - 01:04 AM |
