| ThinAir |
Dec 9 2003, 08:34 AM
Best friends ![]() ![]() ![]() ![]() Group: Members Posts: 2,575 Joined: 4-February 03 From: Flagstaff, AZ Member No.: 231 Region Association: Southwest Region
For awhile now I've had an occasional "buck" when driving at steady speed. The engine just hesitates and then goes right back to running just fine so I haven't been able to pin down what is going on.
Don't know if it's related or not, but this morning after driving for about 20 minutes, suddenly the engine is bucking like crazy as I try to accelerate from a stop. I pull over and the engine dies, but starts right up again. When I try to go, it dies again. Finally it works on the 3rd try, but as I'm driving I notice that the tac needle is jumping all over the place even when the engine isn't bucking and it continues to buck intermittently. Normally I would suspect points, but I'm running a Pertronics Ignitor that has been working fine since I put it in back in May. I've run these units in 5 different Type 1 or 4 air cooled engines and never had a problem. Has mine suddenly gone bad or am I looking for something else? All the connections to the coil & injector triggers seem nice and tight. |
| seanery |
Dec 9 2003, 08:36 AM
waiting to rebuild whitey! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 15,857 Joined: 7-January 03 From: Indy Member No.: 100 Region Association: None |
maybe a major intermitent ground issue?
| TheCabinetmaker |
Dec 9 2003, 09:08 AM
I drive my car everyday ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,377 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
Fuel injected? check the cht connection.
| skline |
Dec 9 2003, 09:36 AM
Born to Drive ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,910 Joined: 26-December 02 From: Costa Mesa, CA Member No.: 17 Region Association: Southern California |
I have to agree with Seanery, it has to be a grounding issue. That would make the tach jump and the engine stutter. Check your wiring for cracks.
| ThinAir |
Dec 13 2003, 09:29 PM
I discovered that the coil had turned in its mounting bracket and one of the connecting wires was apparently coming into contact with the engine tin. I'm running a blue coil and it is smaller than the stock bracket so I had used something to fill the space and apparently it became compacted enough to allow the coil to turn.
The bucking is gone and the tach doesn't swing anymore, but now I've got a new problem that 9 times out of 10 when I try to start the car it will just crank & crank on the first try, but not fire. I turn the key off and try it again and the engine starts right up. Strange... |
Lo-Fi Version | Time is now: 20th June 2026 - 02:54 PM |
