odometer not working, speedometer does |
mattp |
May 30 2007, 11:10 AM
Member Group: Members Posts: 257 Joined: 22-November 06 From: westchester NY Member No.: 7,252 |
the speedometer works, odometer doesnt, but occasionally odometer will turn a couple of tenths of a mile? Any ideas?
914nerd |
May 30 2007, 11:16 AM
Who you callin' a "Member"? Group: Members Posts: 416 Joined: 18-July 06 From: Los Alamos, NM Member No.: 6,461 |
Pull the entirre assembly out and check the pot metal gear that drives the odo.
This gear tends to start to slip on the shaft. If this is the case, tighten it up a little bit, and it should work again Look for the Pelican (I think) article on odometer repair |
Demick |
May 30 2007, 11:22 AM
Ernie made me do it! Group: Benefactors Posts: 2,312 Joined: 6-February 03 From: Pleasanton, CA Member No.: 257 |
Yep. Pelican has a tech article on this. Common failure. Not too difficult to fix. I did this several years ago on my car and it works great.
Brando |
May 30 2007, 11:43 AM
BUY MY SPARE KIDNEY!!! Group: Members Posts: 3,935 Joined: 29-August 04 From: Santa Ana, CA Member No.: 2,648 Region Association: Southern California |
Repaired mine, works like a champ since. (IMG:style_emoticons/default/smile.gif)
Lo-Fi Version | Time is now: 2nd May 2024 - 11:30 PM |
