> Starter is dying...replace w/ 911 unit?, $100 more than a teener unit!
Air_Cooled_Nut
post May 31 2007, 11:17 AM
914 Ronin - 914 owner who lost his 914club.com
Starter works fine when cold. After a some driving, to where the starter gets heat soak, it will crank the engine VERY slowly as if the battery is very low on charge. Acts the same exact way while jump starting. But if I let the car cool down for awhile then it will crank like normal. I even had AAA come out and check the battery and charging system with their uber-cool, $600 hand-held analyzer and everything checked out 100%. So I know my battery (Optima) is in tip-top shape and my alternator is just as good.
I've read the hot-start relay threads and understand them. It's a band-aide for a failing starter as well as a safe-guard for the ignition switch. I may do it, I may not. Not sure. But I do know I need a starter. So, GPR has rebuilt Bosch units for the 911 @ $219 and 914 @ $112. Money is tight for me but I'd rather pay once than twice (IMG:style_emoticons/default/wink.gif)
I want to understand WHY the 911 starter is the prefered unit for replacement. I know it has more cranking power but is it at the same voltage/amperage draw as a 914 unit or more? Does the extra power spin the flywheel faster, resulting in a faster start? (IMG:style_emoticons/default/confused24.gif)
Replies(1 - 19)
post May 31 2007, 11:20 AM
Resident German
i got a aftermarket high-torque starter and never looked back.
better than the stock unit and better than the 911 unit ...
(IMG:style_emoticons/default/cool_shades.gif) Andy
Ferg
post May 31 2007, 11:21 AM
I agree with Andy (IMG:style_emoticons/default/agree.gif)
Ferg
Air_Cooled_Nut
post May 31 2007, 11:22 AM
Ok, but you're not telling me WHY a higher torque starter is better (IMG:style_emoticons/default/blink.gif)
pin31
post May 31 2007, 11:26 AM
smaller, lighter, more torque (more power to spin the flywheel), quicker starts
search for IMI Hi-torque #101. prices vary quite a bit.
VaccaRabite
post May 31 2007, 11:29 AM
En Garde!
I have one of the hi torque starters as well, but its not in the car yet. But, neither is the engine.
zach
post May 31 2007, 12:01 PM
Resident German
QUOTE(Air_Cooled_Nut @ May 31 2007, 09:22 AM) *
uhm, more torque? (IMG:style_emoticons/default/confused24.gif)
(IMG:style_emoticons/default/biggrin.gif) Andy
Ferg
post May 31 2007, 12:17 PM
I have never heard of anyone having a hot start issue with a high torque starter. I can't say the same for rebuilt or new OEM starters
Ferg
McMark
post May 31 2007, 12:21 PM
914 Freak!
The IMI starter is cheaper and BRAND NEW. The Bosch starters are more expensive and rebuilt. Starter technology ain't that grand. If you don't have a high compression motor, you can use almost anything. So there is no huge technical reason to use a high-torque or 911 starter. In this case it's a matter of economics, and IMHO, brand new beats rebuilt every time.
VaccaRabite
post May 31 2007, 01:26 PM
En Garde!
All the above.
Also, the new Hi torque starters are quite a bit lighter then the stock ones too.
Zach
Grimstead
post May 31 2007, 02:48 PM
Cheaky Monkey
Here you go, this is where I bought mine...
eBay 914/911 Mini Starter
Trevorg7
post May 31 2007, 03:15 PM
QUOTE(Ferg @ May 31 2007, 11:17 AM) *
Ferg
This happened to me once last year. 100+ degrees, 60 minutes at freeway speed, shut it down and it would not start for 40 mins. We'll see this summer. The starter below is what I bought and it was 5 months old when it happened.
QUOTE(Grimstead @ May 31 2007, 01:48 PM) *
This has been a good unit other than the hot start noted above.
T
Rand
post May 31 2007, 03:42 PM
Cross Member
Good unit.
"Hot start" issues are another matter... most likely voltage loss over dirty wiring. Starters get blamed for this too often.
McMark
post May 31 2007, 04:55 PM
914 Freak!
(IMG:style_emoticons/default/agree.gif) A solid ground strap, and good battery cables & connections are necessary as well. Far too many original positive battery cables out there if you ask me.
ConeDodger
post May 31 2007, 05:29 PM
Apex killer!
QUOTE(McMark @ May 31 2007, 03:55 PM) *
Mark!!! Shhhhhhhhhhhhhhhhhhhhhh Pat Garvey may be lurking!!! (IMG:style_emoticons/default/biggrin.gif) Sorry Pat!
scotty b
post May 31 2007, 06:59 PM
rust free you say ?
I asked this once before when this subject came up and never got a response so I'll try again. Is the 944 strarter not the same or equivalent of a "high torque" starter? Or am I remembering an article I never read (IMG:style_emoticons/default/huh.gif) Which is entirely possible........
PinetreePorsche
post May 31 2007, 07:10 PM
QUOTE(scotty b @ May 31 2007, 05:59 PM) *
Scotty -- Glasd to have a neighbor in the fray, and a 944 question come up. My "new" '90 S2 944 has a v e r ..y slow starter. Was wondering if a 911-914 mini, high torque would go in the 944. Sounds like that's your hint. Anything I need to know? Thanks
scotty b
post May 31 2007, 07:16 PM
rust free you say ?
Chris if your 944's starter is slow you have another issue. Check your grounds, and battery. They don't spin excessivly fast but 944's do have good starters, that is why I believe I think remembering possibly seeing an article in some magazine at some time in my infintessimile life about 944 starters being great on 911 and 914's .....maybe....... (IMG:style_emoticons/default/blink.gif)
McMark
post May 31 2007, 08:35 PM
914 Freak!
Scotty, I'm guessing there was no response because no one knows for sure. (IMG:style_emoticons/default/wink.gif) Have you seen them side by side to see if there are obvious differences? Have you searched the Pelican 911 forum to see if anyone has mentioned it there? Is the 944 starter better/cheaper/stronger than the hi-torque mini starter?
914Sixer
post May 31 2007, 09:42 PM
The stock starter is .8 hp. The 911 Bosch starter is 1.5 hp. Almost double. I do not know the hp of the hi-performance starter. I have never heard of a hot start problem with a 911 starter after 72 when they went to the larger starter.
- Lo-Fi Version Time is now: 2nd April 2026 - 08:33 AM
