> Back window film
ruddyboys
post Jun 1 2007, 02:12 PM
Hummel eigentümer
The PO put in some blackout film on the back window. It made seeing out the little window worst than it really is, so being the brain surgen that I am, I took my trustly utility knife and cut a piece out of the center hoping to just peel it off, behind the small piece left some really bad residue were I can't even see out the rear window, before I pull off the rest what can I use to remove the residue?
mills914/s
post Jun 1 2007, 02:24 PM
A razor blade/goof off.
Or if you can find it 3M brand acrosol.Works the best.
I used to tint windows... It sucks getting that glue off.
Have fun. Dont cut yourself.
zymurgist
post Jun 1 2007, 02:43 PM
"Ace" Mechanic
I like acetone for removing old glue, but you have to be careful with it.
1. Use acetone (or Goof-Off, which I think is the same stuff but in a more expensive package) only in a well-ventilated area.
2. Don't spill it on anything vinyl or plastic. These are solvents and they will leave a mark.
sanman
post Jun 1 2007, 05:16 PM
Leaving California
no need for harsh chem jus some window cleaner and a razor blade.
- Lo-Fi Version Time is now: 7th October 2026 - 03:21 AM
