Targa Tops, The differences between early and late |
PRS914-6 |
Jun 20 2007, 09:52 PM
Excellence Magazine Project 914 3.6 Group: Retired Members Posts: 1,278 Joined: 20-May 06 From: Central California Member No.: 6,031 Region Association: None |
The differences between the early (pre 73) and later Targa tops is shown below. The most significant difference is the step where the window seals attach. I suspect due to the different windows used in the 73 up cars. I'm checking that out now. The step is noticeably taller or hangs lower on the later tops.
Other differences are shown but I suspect they won't have a major impact. Thanks for those at WCR who volunteered their tops for the inspection |
AZBanks |
Jul 19 2018, 07:27 PM
Senior Member Group: Members Posts: 1,063 Joined: 7-December 05 From: New River, AZ Member No.: 5,245 Region Association: Southwest Region |
My plan is to swap all the hardware from the late body to the early body and then just use the entire late top.
What I was really wondering is if the hardware mounts on the body are different from early to late. If all the hardware mounts are the same, the swap should work perfectly. |
SirAndy |
Jul 19 2018, 08:58 PM
Resident German Group: Admin Posts: 41,651 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
What I was really wondering is if the hardware mounts on the body are different from early to late. If all the hardware mounts are the same, the swap should work perfectly. That part should be the same. Post your results here ... (IMG:style_emoticons/default/beerchug.gif) |
Lo-Fi Version | Time is now: 21st May 2024 - 03:56 PM |
