Targa Tops, The differences between early and late |
PRS914-6 |
Jun 20 2007, 09:52 PM
Excellence Magazine Project 914 3.6 Group: Retired Members Posts: 1,278 Joined: 20-May 06 From: Central California Member No.: 6,031 Region Association: None |
The differences between the early (pre 73) and later Targa tops is shown below. The most significant difference is the step where the window seals attach. I suspect due to the different windows used in the 73 up cars. I'm checking that out now. The step is noticeably taller or hangs lower on the later tops.
Other differences are shown but I suspect they won't have a major impact. Thanks for those at WCR who volunteered their tops for the inspection |
Slick914 |
Feb 15 2009, 12:59 PM
Member Group: Members Posts: 236 Joined: 10-June 07 From: Lorain, OH Member No.: 7,802 |
This is good information. Maybe it would be better suited in the originality forum where it might be easier to find?
My 73 has an early top according to the info here. Is it possible that my 73 came with the early top or is it certain that it was replaced at some point in time? It seams to fit pretty good. (IMG:style_emoticons/default/confused24.gif) |
dw914er |
Feb 15 2009, 01:11 PM
Planning Cities Group: Members Posts: 2,364 Joined: 1-March 08 From: Yucaipa, CA Member No.: 8,763 Region Association: Southern California |
This is good information. Maybe it would be better suited in the originality forum where it might be easier to find? My 73 has an early top according to the info here. Is it possible that my 73 came with the early top or is it certain that it was replaced at some point in time? It seams to fit pretty good. (IMG:style_emoticons/default/confused24.gif) im pretty sure my 73 has an early top too... if thats the case then thats the way my car came. |
SirAndy |
Feb 15 2009, 03:42 PM
Resident German Group: Admin Posts: 41,607 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
This is good information. Maybe it would be better suited in the originality forum where it might be easier to find? My 73 has an early top according to the info here. Is it possible that my 73 came with the early top or is it certain that it was replaced at some point in time? It seams to fit pretty good. (IMG:style_emoticons/default/confused24.gif) im pretty sure my 73 has an early top too... if thats the case then thats the way my car came. '73 was a transition year. If you have a '73 with a early top, i suspect you also have the early windows and mechanism, as they go together. (IMG:style_emoticons/default/shades.gif) Andy |
dw914er |
Feb 15 2009, 03:58 PM
This is good information. Maybe it would be better suited in the originality forum where it might be easier to find? My 73 has an early top according to the info here. Is it possible that my 73 came with the early top or is it certain that it was replaced at some point in time? It seams to fit pretty good. (IMG:style_emoticons/default/confused24.gif) im pretty sure my 73 has an early top too... if thats the case then thats the way my car came. '73 was a transition year. If you have a '73 with a early top, i suspect you also have the early windows and mechanism, as they go together. (IMG:style_emoticons/default/shades.gif) Andy which month was the turn around? My car was built july 73, so I suspect that august+ was the later then? |
rascobo |
Feb 15 2009, 04:29 PM
Member Group: Members Posts: 203 Joined: 26-July 07 From: Portland,OR. Member No.: 7,948 Region Association: Pacific Northwest |
This is good information. Maybe it would be better suited in the originality forum where it might be easier to find? My 73 has an early top according to the info here. Is it possible that my 73 came with the early top or is it certain that it was replaced at some point in time? It seams to fit pretty good. (IMG:style_emoticons/default/confused24.gif) im pretty sure my 73 has an early top too... if thats the case then thats the way my car came. '73 was a transition year. If you have a '73 with a early top, i suspect you also have the early windows and mechanism, as they go together. (IMG:style_emoticons/default/shades.gif) Andy which month was the turn around? My car was built july 73, so I suspect that august+ was the later then? Add My '73 to the others with an early top, but definately the late model window mechanism. I've don't believe any '73s came with early windows, so it seems unlikely so many '73s would be running around with the early tops if they were incompatible. (IMG:style_emoticons/default/shades.gif) (right back at Ya!) (IMG:style_emoticons/default/av-943.gif) Scott |
SirAndy |
Feb 15 2009, 04:39 PM
would be running around with the early tops if they were incompatible. (IMG:style_emoticons/default/shades.gif) (right back at Ya!) (IMG:style_emoticons/default/av-943.gif) I've got a late top and early windows and it does not seal right at all. The top should match the windows ... (IMG:style_emoticons/default/shades.gif) Andy PS: Maybe the transition year was '72, can't remember. Somewhere in there they switched windows and tops ... |
Lo-Fi Version | Time is now: 30th April 2024 - 04:52 PM |
