2.0 rod and main bearing specifications, does anybody know the standard spec. |
orange914 |
Jun 29 2007, 12:47 AM
http://5starmediaworks.com/index.html Group: Members Posts: 3,371 Joined: 26-March 05 From: Ceres, California Member No.: 3,818 Region Association: Northern California |
does anybody know the measurements or where i can link to them? (IMG:style_emoticons/default/poke.gif) ?
mike |
G e o r g e |
Jun 29 2007, 01:27 AM
Dr Group: Members Posts: 1,905 Joined: 20-September 05 From: Southern Cal Member No.: 4,832 Region Association: None |
try here
or 0.02- 0.07 wear limit 0.15 for rods main bearings bearings# 1 & 3 .002-.004 wear limits .18 bearing# 2 .03- .09 wear limits .17 bearing# 4 .002- .004 wear limit .19 all mesurenments are MM |
sww914 |
Jun 29 2007, 01:40 AM
All of the sizes are in even numbers in metric, no fractions.
Resizing is done in 1/4mm increments. So, if a crank journal is say 32mm, (arbitrary number) it's standard. If it's been machined down once, it will be 31.75mm, twice will be 31.5mm, and so on. The same is true for the case. A standard bearing journal will be say 50mm, if it's been align bored it'll be 50.25mm, 50.5mm, whatever. I'm sorry I don't know the exact numbers, this is what I've needed to know in the past to figure out what I need to order. |
Lo-Fi Version | Time is now: 10th June 2024 - 12:40 AM |
