A little help with the PP site. |
KaptKaos |
Jul 1 2007, 11:23 PM
Family Group: Members Posts: 4,009 Joined: 23-April 03 From: Near Wausau Member No.: 607 Region Association: Upper MidWest |
Can anyone here tell me if Pelican sells a set of screws for cooling tin? I Have a new-to-me motor and I need to attach the tin.
Thanks in advance. |
Grimstead |
Jul 1 2007, 11:35 PM
Cheaky Monkey Group: Members Posts: 835 Joined: 20-March 05 From: Corona, Ca Member No.: 3,789 Region Association: Southern California |
I don't know about PP but they have them here
wolfsburgwest.com They are here in Corona too. I'm pretty sure any VW place should have them as well and if you do a search on 'cheesehead' (maybe one or two words), some people were switching them with allen head screws. Also, there are two different The More You Know.... This post has been edited by Grimstead: Jul 2 2007, 09:57 AM |
KaptKaos |
Jul 2 2007, 01:22 AM
Thanks Bill.
We are getting down to the home stretch! |
KaptKaos |
Jul 2 2007, 01:24 AM
Next question.
Anyone know who makes and where to buy those thick gaskets for the weber 44 idf manifolds? The ones that go on the head side? Thanks! |
McMark |
Jul 2 2007, 01:36 AM
Tin screws are all the same (6mm x 1.00) although some have been stripped out and enlarged.
The intake gasket is a standard Type IV intake gasket. (IMG:style_emoticons/default/thumb3d.gif) |
sean_v8_914 |
Jul 2 2007, 02:18 AM
where are you in LA? there are MANY VW shops there that sell weber parts and cheese head screws
sean_v8_914 |
Jul 2 2007, 02:26 AM
what is closer, venice, Azuza, long beach, Santa Monica?
rhodyguy |
Jul 2 2007, 08:31 AM
you might consider using the stock fi phenolic gaskets. #022-129-707F for 4 stud heads, #039-129-707 M17 for 3 stud. i run them on my weber setup to help with the heat soak issue. jake offers, or was going to, his own version too. i like the phillips head version of the screws. easier to work with.
fwiw, i use the same locking washers (new), as used on the cv joint bolts, for the head to maniflold and carb to manifold studs. they are the correct size, work great, and don't cut/gall into the aluminum when you tighten them down like cut steel washers do. k |
KaptKaos |
Jul 2 2007, 08:39 AM
KaptKaos |
Jul 2 2007, 08:40 AM
you might consider using the stock fi phenolic gaskets. #022-129-707F for 4 stud heads, #039-129-707 M17 for 3 stud. i run them on my weber setup to help with the heat soak issue. jake offers, or was going to, his own version too. i like the phillips head version of the screws. easier to work with. k Ok, so they are a stock part then, which works just fine. I will check that out. Thanks for the help! |
Borderline |
Senior Member Group: Members Posts: 720 Joined: 8-February 05 From: San Juan Bautista, CA Member No.: 3,577 Region Association: Northern California |
I went with hex head screws from OSH. I like being able to put a wrench on em.
ruddyboys |
Jul 2 2007, 08:47 AM
Hummel eigentümer Group: Members Posts: 594 Joined: 3-March 04 From: Monroe, NY Member No.: 1,749 Region Association: North East States |
I went to the local ACE Hardware and got metric philips pan head screws for like 8 cents each
Cap'n Krusty |
Jul 2 2007, 09:54 AM
Becaust the Weber manifolds are a LOT thicker than the original manifolds, you'll need longer intake manifold studs. BE VERY CAREFUL removing the old studs. They have a nasty habit of taking the threads with them. The Cap'n
rhodyguy |
Jul 2 2007, 10:05 AM
in my case, i did not have to change out the intake studs on the 2.0 fi engine i just installed running the fi gaskets and cb tall manifolds. yrmv. the schnor(?) washers are thin enough that they buy you a little xtra room as compared to thick ass cut washers.
k |
ptravnic |
Jul 2 2007, 10:07 AM
Senior Member Group: Members Posts: 1,231 Joined: 27-May 03 From: Chicago, IL Member No.: 747 Region Association: None |
I went to the local ACE Hardware and got metric philips pan head screws for like 8 cents each I did something similar - bought a box of 50 6mm x 1.0 pitch x 10mm length, and a box of 50 12mm length phillips screws. I dip each screw end in grease b4 putting them in & have had success in removing them (with ease) 5 or 6yrs later. Some places the 12mm's work better than the 10mm's. For the magnesium, hex heads (of diffrerent lenghts) are my preference but careful not to overtighten (easy to do w/a wrench) - the 6mm threads can't take much torque. hex heads might be nice for replacing all the screws but seems to me a screwdriver is easier to get into some of the areas down the road should you need to remove them w/the engine in the car. Guess it's a personal preference... -pt |
rhodyguy |
Jul 2 2007, 10:18 AM
when you're buying, get enough new ones for all the heat exchanger to case and heat ducting related tin. the phillips head screws are easier to install than the slotted type when you're laying on your back trying to balance a screw on a screw driver.
k |
Lo-Fi Version | Time is now: 18th May 2024 - 05:02 AM |
